[MOAB-dev] Changing the options format in iMesh
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Mon Nov 15 12:18:30 CST 2010
On 11/15/2010 12:13 PM, James Porter wrote:
> In order to be compatible with the iMesh spec, we need to change the
> options format. Currently, it seems that MOAB uses the old iMesh-defined
> options syntax. Should we continue to support this syntax, or should
> MOAB use the new iMesh syntax? (Or maybe MOAB should have its own
> syntax?)
MOAB already has its own syntax and I don't see any advantage to changing it.
> For reference, the new way is "impl1:opt1 impl2:opt2", e.g. "moab:silent
> moab:foobar". If MOAB got its own syntax instead of just doing this, I'd
> expect the options to look like "silent foobar" by the time it got to
> MOAB.
That should actually be "; silent foobar" when passed to MOAB.
> Options for other implementations would be stripped at the iMesh
> level.
This seems like the obvious place to do so, as there are many iMesh
implementations but only one MOAB implementation.  An implementation prefix
at the MOAB level wouldn't make sense.
- jason
