[MOAB-dev] iMesh_unitTest results for MOAB
James Porter jvporter at wisc.edu
Fri Nov 12 15:18:04 CST 2010
After a couple of tweaks so that iMesh_unitTest doesn't segfault due to
our lack of support for septahedrons, I managed to get the entire
iMesh_unitTest to run, and here are the results.
- Jim
./iMesh_unitTest globe_mats.vtk
Testing mesh interface...
 Getting geometric dimension... 3
Getting default storage order...
 Getting adjacency table.
 Global entity query tests
  Type:    vertex Topology:          point OK
  Type:    vertex Topology:   line segment threw an error, as expected.
  Type:    vertex Topology:        polygon threw an error, as expected.
  Type:    vertex Topology:       triangle threw an error, as expected.
  Type:    vertex Topology:  quadrilateral threw an error, as expected.
  Type:    vertex Topology:     polyhedron threw an error, as expected.
  Type:    vertex Topology:    tetrahedron threw an error, as expected.
  Type:    vertex Topology:        pyramid threw an error, as expected.
  Type:    vertex Topology:          prism threw an error, as expected.
  Type:    vertex Topology:     hexahedron threw an error, as expected.
  Type:    vertex Topology:    septahedron succeeded when it should have thrown an error.
  Type:    vertex Topology: all topologies OK
  Type:      edge Topology:          point threw an error, as expected.
  Type:      edge Topology:   line segment OK
  Type:      edge Topology:        polygon threw an error, as expected.
  Type:      edge Topology:       triangle threw an error, as expected.
  Type:      edge Topology:  quadrilateral threw an error, as expected.
  Type:      edge Topology:     polyhedron threw an error, as expected.
  Type:      edge Topology:    tetrahedron threw an error, as expected.
  Type:      edge Topology:        pyramid threw an error, as expected.
  Type:      edge Topology:          prism threw an error, as expected.
  Type:      edge Topology:     hexahedron threw an error, as expected.
  Type:      edge Topology:    septahedron threw an error, as expected.
  Type:      edge Topology: all topologies OK
  Type:      face Topology:          point threw an error, as expected.
  Type:      face Topology:   line segment threw an error, as expected.
  Type:      face Topology:        polygon OK
  Type:      face Topology:       triangle OK
  Type:      face Topology:  quadrilateral OK
  Type:      face Topology:     polyhedron threw an error, as expected.
  Type:      face Topology:    tetrahedron threw an error, as expected.
  Type:      face Topology:        pyramid threw an error, as expected.
  Type:      face Topology:          prism threw an error, as expected.
  Type:      face Topology:     hexahedron threw an error, as expected.
  Type:      face Topology:    septahedron threw an error, as expected.
  Type:      face Topology: all topologies OK
  Type:    region Topology:          point threw an error, as expected.
  Type:    region Topology:   line segment threw an error, as expected.
  Type:    region Topology:        polygon threw an error, as expected.
  Type:    region Topology:       triangle threw an error, as expected.
  Type:    region Topology:  quadrilateral threw an error, as expected.
  Type:    region Topology:     polyhedron OK
  Type:    region Topology:    tetrahedron OK
  Type:    region Topology:        pyramid OK
  Type:    region Topology:          prism OK
  Type:    region Topology:     hexahedron OK
  Type:    region Topology:    septahedron
Threw an error instead of returning!
type and topology are inconsistant
  Type:    region Topology: all topologies OK
  Type: all types Topology:          point OK
  Type: all types Topology:   line segment OK
  Type: all types Topology:        polygon OK
  Type: all types Topology:       triangle OK
  Type: all types Topology:  quadrilateral OK
  Type: all types Topology:     polyhedron OK
  Type: all types Topology:    tetrahedron OK
  Type: all types Topology:        pyramid OK
  Type: all types Topology:          prism OK
  Type: all types Topology:     hexahedron OK
  Type: all types Topology:    septahedron OK
  Type: all types Topology: all topologies OK
 Verifying that getVtxArrCoords requires vertex handles as input...
Test results so far:  64 passed, 2 failed.
 Verifying retrieved entity type and topology
At line 1425 in iMesh_unitTest.cc, hit error:  type and topology are inconsistant
 Checking single vertex coordinate retrieval
 Checking single entity adjacency calls
   Adjacent entity type:       edge
   Adjacent entity type:       face
   Adjacent entity type:     region
   Adjacent entity type:     vertex
At line 1536 in iMesh_unitTest.cc, hit error:  type and topology are inconsistant
  Source type:    vertex  Bridge type:    vertex Target type:    vertex
  Source type:    vertex  Bridge type:    vertex Target type:      edge
  Source type:    vertex  Bridge type:    vertex Target type:      face
  Source type:    vertex  Bridge type:    vertex Target type:    region
iMesh_unitTest.cc:883: Failure testing qOK
  Source type:    vertex  Bridge type:    vertex Target type: all types
  Source type:    vertex  Bridge type:      edge Target type:    vertex
  Source type:    vertex  Bridge type:      edge Target type: all types
  Source type:    vertex  Bridge type:      face Target type:    vertex
  Source type:    vertex  Bridge type:      face Target type: all types
  Source type:    vertex  Bridge type:    region Target type:    vertex
  Source type:    vertex  Bridge type:    region Target type:    region
  Source type:    vertex  Bridge type:    region Target type: all types
  Source type:    vertex  Bridge type: all types Target type:    vertex
  Source type:    vertex  Bridge type: all types Target type:      edge
  Source type:    vertex  Bridge type: all types Target type:      face
  Source type:    vertex  Bridge type: all types Target type:    region
  Source type:    vertex  Bridge type: all types Target type: all types
  Source type:      edge  Bridge type:    vertex Target type:    vertex
  Source type:      edge  Bridge type:    vertex Target type:      edge
  Source type:      edge  Bridge type:    vertex Target type:      face
  Source type:      edge  Bridge type:    vertex Target type:    region
  Source type:      edge  Bridge type:    vertex Target type: all types
  Source type:      edge  Bridge type:      edge Target type: all types
  Source type:      edge  Bridge type:      face Target type: all types
  Source type:      edge  Bridge type:    region Target type: all types
  Source type:      edge  Bridge type: all types Target type:    vertex
  Source type:      edge  Bridge type: all types Target type:      edge
  Source type:      edge  Bridge type: all types Target type:      face
  Source type:      edge  Bridge type: all types Target type:    region
  Source type:      edge  Bridge type: all types Target type: all types
  Source type:      face  Bridge type:    vertex Target type:    vertex
  Source type:      face  Bridge type:    vertex Target type:      edge
  Source type:      face  Bridge type:    vertex Target type:      face
  Source type:      face  Bridge type:    vertex Target type:    region
  Source type:      face  Bridge type:    vertex Target type: all types
  Source type:      face  Bridge type:      edge Target type: all types
  Source type:      face  Bridge type:      face Target type: all types
  Source type:      face  Bridge type:    region Target type: all types
  Source type:      face  Bridge type: all types Target type:    vertex
  Source type:      face  Bridge type: all types Target type:      edge
  Source type:      face  Bridge type: all types Target type:      face
  Source type:      face  Bridge type: all types Target type:    region
  Source type:      face  Bridge type: all types Target type: all types
  Source type:    region  Bridge type:    vertex Target type:    vertex
  Source type:    region  Bridge type:    vertex Target type:      edge
  Source type:    region  Bridge type:    vertex Target type:      face
  Source type:    region  Bridge type:    vertex Target type:    region
  Source type:    region  Bridge type:    vertex Target type: all types
  Source type:    region  Bridge type:      edge Target type: all types
  Source type:    region  Bridge type:      face Target type: all types
  Source type:    region  Bridge type:    region Target type:    vertex
  Source type:    region  Bridge type:    region Target type:    region
  Source type:    region  Bridge type:    region Target type: all types
  Source type:    region  Bridge type: all types Target type:    vertex
  Source type:    region  Bridge type: all types Target type:      edge
  Source type:    region  Bridge type: all types Target type:      face
  Source type:    region  Bridge type: all types Target type:    region
  Source type:    region  Bridge type: all types Target type: all types
 Testing single entity iterators
At line 1605 in iMesh_unitTest.cc, hit error:  type and topology are inconsistant
 Testing single entity adjacency reciprocity
  Edges and verts: passed passed
  Faces and verts: passed passed
  Regions and verts: passed passed
Entity adjacency identity test...
  Type:    vertex
  Type:    region
Test results so far:  171 passed, 15 failed.
 Verifying retrieved entity type and topology (array version)
    and global entity adjacency
   Adjacent type:      edge
   Adjacent type:      face
   Adjacent type:    region
   Adjacent type:      edge
   Adjacent type:      face
   Adjacent type:    vertex
At line 1869 in iMesh_unitTest.cc, hit error:  type and topology are inconsistant
 Testing array iterators
At line 2011 in iMesh_unitTest.cc, hit error:  type and topology are inconsistant
 Testing entity array adjacency reciprocity
 Array adjacency identity test...
  Type:    vertex
  Type:    region
Test results so far:  271 passed, 17 failed.
Modify interface is currently only tested thoroughly in 2D
 Setting vertex coordinates...
At line 283 in iMesh_unitTest.cc, hit error:  iMesh_save:ERROR saving a mesh.  (MOAB Error Code: MB_UNHANDLED_OPTION)
Unable to load file "/tmp/iMesh_unitTest_data_0"
The file name extension suggests this is NOT a VTK file.
Not all implementations read the same file formats.
You may wish to independently confirm that the iMesh
implementation you have linked to can indeed read this file.
In addition, also be aware that for purposes of testing
the input mesh must have >55 vertices and >10 elements
At line 325 in iMesh_unitTest.cc, hit error:  iMesh_load:ERROR loading a mesh.  (MOAB Error Code: MB_UNHANDLED_OPTION)
 Creating a new vertex...
 Creating mini 3D mesh...
   Creating eight vertices...
Test results so far:  274 passed, 19 failed.
 Creating new vertices...
Unable to load file "/tmp/iMesh_unitTest_data_1"
Unable to load file "/tmp/iMesh_unitTest_data_2"
Test results so far:  277 passed, 23 failed.
Testing entity set interface...
Testing creation, basic methods, deletion...              DONE
Testing addition and removal for sets in sets...          At line 283 in iMesh_unitTest.cc, hit error:  iMesh_save:ERROR saving a mesh.  (MOAB Error Code: MB_UNHANDLED_OPTION)
Unable to load file "/tmp/iMesh_unitTest_data_3"
iMesh_unitTest.cc:3322: Failure testing (aiDirect[iSet] == iDirect) && (aiDirect[iSet] == iDirectRet) && qGotAllSets
iMesh_unitTest.cc:3332: Failure testing (aiTwoLayer[iSet] == iTwoLayer) && (aiTwoLayer[iSet] == iTwoLayerRet) && qGotAllSets
DONE
Testing addition and removal for entities in sets...      At line 283 in iMesh_unitTest.cc, hit error:  iMesh_save:ERROR saving a mesh.  (MOAB Error Code: MB_UNHANDLED_OPTION)
Unable to load file "/tmp/iMesh_unitTest_data_4"
Unable to load file "/tmp/iMesh_unitTest_data_5"
DONE
Unable to load file "/tmp/iMesh_unitTest_data_6"
Unable to load file "/tmp/iMesh_unitTest_data_7"
Test results so far:  367 passed, 37 failed.
Testing relations and parent/child queries...             DONE
Unable to load file "/tmp/iMesh_unitTest_data_8"
iMesh_unitTest.cc:574: Failure testing apvEntSets[ii] != NULL
Testing ability to get children/parents...
iMesh_unitTest.cc:3744: Failure testing qNumsOK
iMesh_unitTest.cc:3754: Failure testing qGotAllSets && iNumSets == aiTotalChld[i]
iMesh_unitTest.cc:3761: Failure testing qGotAllSets && iNumSets == aiDirectChld[i]
iMesh_unitTest.cc:3768: Failure testing qGotAllSets && iNumSets == aiTwoLayerChld[i]
iMesh_unitTest.cc:3775: Failure testing qGotAllSets && iNumSets == aiTotalPrnt[i]
iMesh_unitTest.cc:3782: Failure testing qGotAllSets && iNumSets == aiDirectPrnt[i]
iMesh_unitTest.cc:3789: Failure testing qGotAllSets && iNumSets == aiTwoLayerPrnt[i]
DONE
Testing relation removal...                               At line 3876 in iMesh_unitTest.cc, hit error:  iMesh_rmvPrntChld: ERROR RemoveParentChild failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
At line 3883 in iMesh_unitTest.cc, hit error:  iMesh_rmvPrntChld: ERROR RemoveParentChild failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
At line 3890 in iMesh_unitTest.cc, hit error:  iMesh_rmvPrntChld: ERROR RemoveParentChild failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
Unable to load file "/tmp/iMesh_unitTest_data_9"
DONE
Test results so far:  408 passed, 88 failed.
Testing methods with regular sets and lists...
Testing intersect with regular lists...
iMesh_unitTest.cc:245: Failure testing (iIsList == iShouldBeList) && qGotAllSets && qGotAllEnts
DONE
Testing intersect with regular sets...
DONE
Testing intersect with sets and lists...
DONE
Testing subtract with regular lists...
DONE
Testing subtract with regular sets...
DONE
Testing subtract with lists and sets...
DONE
Testing unite with regular lists...
DONE
Testing unite with regular sets...
DONE
Testing unite with lists and sets...
DONE
Testing methods with the root set... may take a while...
Testing intersect with the root set...                    At line 4310 in iMesh_unitTest.cc, hit error:  iMesh_entitysetIntersect: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
At line 4315 in iMesh_unitTest.cc, hit error:  iMesh_entitysetIntersect: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
DONE
Testing subtract with the root set...                     At line 4328 in iMesh_unitTest.cc, hit error:  iMesh_entitysetSubtract: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
At line 4333 in iMesh_unitTest.cc, hit error:  iMesh_entitysetSubtract: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
iMesh_unitTest.cc:4378: Failure testing qIsEmpty && qGotAllItems && !iIsList
DONE
Testing unite with the root set...                        At line 4391 in iMesh_unitTest.cc, hit error:  iMesh_entitysetIntersect: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
At line 4406 in iMesh_unitTest.cc, hit error:  iMesh_entitysetIntersect: ERROR subtract failed.  (MOAB Error Code: MB_ENTITY_NOT_FOUND)
DONE
Test results so far:  422 passed, 126 failed.
Unable to load file "/tmp/iMesh_unitTest_data_10"
Testing basic queries...                                  DONE
Testing entity retrieval...                               DONE
Unable to load file "/tmp/iMesh_unitTest_data_11"
Testing entity adjacency consistency...
  Type:    vertex      with topology:          point
   Checking adjacency for entity type:	   vertex		DONE
   Checking adjacency for entity type:	     edge		DONE
   Checking adjacency for entity type:	     face		DONE
   Checking adjacency for entity type:	   region		DONE
  Type:    region      with topology:    tetrahedron
  Type:    region      with topology:        pyramid
  Type:    region      with topology:          prism
  Type:    region      with topology:     hexahedron
Unable to load file "/tmp/iMesh_unitTest_data_12"
Test results so far:  481 passed, 132 failed.
Testing single entity iterators with entity sets...
Testing set iterator initialization...                    DONE
Testing set iterator entity retrieval...
iMesh_unitTest.cc:5181: Failure testing qGotData
iMesh_unitTest.cc:5257: Failure testing qGotData
DONE
Testing reset, with removal and addition mid-traversal...
iMesh_unitTest.cc:5360: Failure testing false
iMesh_unitTest.cc:5415: Failure testing false
iMesh_unitTest.cc:5519: Failure testing false
iMesh_unitTest.cc:5568: Failure testing false
DONE
Testing set iterator termination...                       DONE
Test results so far:  537 passed, 141 failed.
Testing entity array iterators over entity sets...
Testing set array iterator entity retrieval...
iMesh_unitTest.cc:5946: Failure testing qGotData
iMesh_unitTest.cc:6033: Failure testing qGotData
DONE
iMesh_unitTest.cc:6172: Failure testing false
iMesh_unitTest.cc:6246: Failure testing false
iMesh_unitTest.cc:6381: Failure testing false
iMesh_unitTest.cc:6452: Failure testing false
DONE
Testing set array iterator termination...                 DONE
Test results so far:  582 passed, 150 failed.
Testing tag interface...
Creating tags of each type...                             DONE
Testing tag destruction...                                DONE
Test results so far:  587 passed, 150 failed.
Testing entity tag interface...
Testing basic tagging functionality...
Testing get and set methods with integers...              DONE
Testing get and set methods with doubles...               DONE
Testing get and set methods with entity handles...        DONE
Testing get and set methods with generic data (bytes)...  DONE
Testing tag finding...                                    DONE
Unable to load file "/tmp/iMesh_unitTest_data_13"
Testing get again after save/load...
Testing get with integers...              DONE
Testing tag removal and forced/unforced destruction...    At line 7069 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and entities are still assigned this tag.
Instead, hit error:
At line 7073 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and entities are still assigned this tag.
Instead, hit error:
DONE
Test results so far:  608 passed, 154 failed.
Testing array tag interface...
Testing basic array tagging functionality...
Testing tag removal and forced/unforced destruction...    At line 7430 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and entities are still assigned this tag.
Instead, hit error:
At line 7433 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and entities are still assigned this tag.
Instead, hit error:
DONE
Test results so far:  617 passed, 156 failed.
Testing entity set tag interface...
Testing entity set tagging functionality...
Unable to load file "/tmp/iMesh_unitTest_data_14"
Retesting get methods after load/save...
Testing get method with integers...              DONE
Testing get method with doubles...               DONE
Testing get method with generic data (bytes)...  DONE
Testing tag removal and forced/unforced destruction...    At line 7821 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and mesh is still assigned this tag.
Instead, hit error:
At line 7825 in iMesh_unitTest.cc, should have hit error:  iMesh_destroyTag: forced=false and mesh is still assigned this tag.
Instead, hit error:
DONE
Test results so far:  637 passed, 160 failed.
Testing lower geometric dimensioned meshes...
Test results so far:  645 passed, 160 failed.
FINAL RESULTS:  645 tests passed,
                160 tests failed in a total of
                805 tests, a pass rate of 80%.
                 16 interfaces/interface combinations were tested:
                 10 passed all interface-specific tests and
                  6 failed at least one test.
