[MOAB-dev] r4264 - MOAB/trunk/tools/dagmc
    sjackson at cae.wisc.edu
    Fri Nov 12 12:45:21 CST 2010
Author: sjackson
Date: 2010-11-12 12:45:20 -0600 (Fri, 12 Nov 2010)
New Revision: 4264
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
Make DagMC print more details when a file loading error occurs.
Also remove an outdated and confusing comment.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2010-11-11 23:44:56 UTC (rev 4263)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2010-11-12 18:45:20 UTC (rev 4264)
@@ -161,7 +161,6 @@
   sprintf(facetTolStr,"%g",facetingTolerance);
-  // what if we are using default faceting tolerance???
   char options[120] = "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=";
   strcat(options,facetTolStr);
@@ -182,6 +181,10 @@
   else if (MB_SUCCESS != rval) {
     std::cerr << "DagMC Couldn't read file " << cfile << std::endl;
+    std::string message;
+    if (MB_SUCCESS == MBI->get_last_error(message) && !message.empty())
+        std::cerr << "Error message: " << message << std::endl;
     return rval;
