[MOAB-dev] r4263 - MOAB/trunk/src/io
iulian at mcs.anl.gov
Thu Nov 11 17:44:56 CST 2010
Author: iulian
Date: 2010-11-11 17:44:56 -0600 (Thu, 11 Nov 2010)
New Revision: 4263
Modified:
MOAB/trunk/src/io/Tqdcfr.cpp
Log:
truncate in the cubit reader the names that are too long
(group names, volume names, attribute names)
also, comment out the asserts that involve the size of the name tag.
we should at least warn the user about truncating.
Maybe a better solution would be to allow a variable size for name tag
Modified: MOAB/trunk/src/io/Tqdcfr.cpp
--- MOAB/trunk/src/io/Tqdcfr.cpp 2010-11-11 22:22:33 UTC (rev 4262)
+++ MOAB/trunk/src/io/Tqdcfr.cpp 2010-11-11 23:44:56 UTC (rev 4263)
@@ -924,7 +924,7 @@
int md_index = md.get_md_entry(set_index, "Name");
if (-1 == md_index) return result;
MetaDataContainer::MetaDataEntry *md_entry = &(md.metadataEntries[md_index]);
- assert(md_entry->mdStringValue.length()+1 <= NAME_TAG_SIZE);
+ //assert(md_entry->mdStringValue.length()+1 <= NAME_TAG_SIZE);
char name_tag_data[NAME_TAG_SIZE];
memset( name_tag_data, 0, NAME_TAG_SIZE ); // make sure any extra bytes zeroed
strncpy( name_tag_data, md_entry->mdStringValue.c_str(), NAME_TAG_SIZE );
@@ -945,7 +945,7 @@
Tag extra_name_tag;
result = mdbImpl->tag_get_handle(moab_extra_name.str().c_str(), extra_name_tag);
if (MB_SUCCESS != result || 0 == extra_name_tag) {
result = mdbImpl->tag_create(moab_extra_name.str().c_str(), NAME_TAG_SIZE, MB_TAG_SPARSE,
@@ -1003,7 +1003,7 @@
if (0 == entityNameTag) return MB_FAILURE;
result = mdbImpl->tag_set_data(entityNameTag, &grouph->setHandle, 1,
@@ -1023,7 +1023,7 @@
md_entry = &(model->groupMD.metadataEntries[md_index]);
Tag extra_name_tag;
@@ -2393,6 +2393,8 @@
size_t len = name_tag.size();
+ if (len>=NAME_TAG_SIZE)
+ len = NAME_TAG_SIZE-1;// truncate a name that is too big
memcpy( name_tag_val, name_tag.c_str(), len );
memset( name_tag_val+len, '\0', NAME_TAG_SIZE-len );
result = mdbImpl->tag_set_data(entityNameTag, &(records[entity_rec_num].entity), 1, name_tag_val);
