[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Fri Sep  3 00:13:40 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/256
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
./obb_test[0x41a2d4]
./obb_test[0x41a569]
./obb_test[0x412283]
./obb_test[0x40aa7f]
./obb_test[0x40e289]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2aee2e5851c4]
./obb_test(__gxx_personality_v0+0x1c9)[0x407979]
======= Memory map: ========
00400000-00561000 r-xp 00000000 09:00 7193678                            /disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/test/obb/obb_test
00760000-00762000 rw-p 00160000 09:00 7193678                            /disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/test/obb/obb_test
00762000-0083c000 rw-p 00762000 00:00 0                                  [heap]
2aee2cf75000-2aee2cf92000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2aee2cf92000-2aee2cf96000 rw-p 2aee2cf92000 00:00 0
2aee2d192000-2aee2d194000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2aee2d194000-2aee2d1b2000 r-xp 00000000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2aee2d1b2000-2aee2d3b1000 ---p 0001e000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2aee2d3b1000-2aee2d3b3000 rw-p 0001d000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2aee2d3b3000-2aee2d3e7000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2aee2d3e7000-2aee2d5e7000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2aee2d5e7000-2aee2d5e8000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2aee2d5e8000-2aee2d5ea000 rw-p 2aee2d5e8000 00:00 0
2aee2d5ea000-2aee2d782000 r-xp 00000000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2aee2d782000-2aee2d981000 ---p 00198000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2aee2d981000-2aee2d98b000 rw-p 00197000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2aee2d98b000-2aee2d999000 rw-p 2aee2d98b000 00:00 0
2aee2d999000-2aee2d9af000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2aee2d9af000-2aee2dbaf000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2aee2dbaf000-2aee2dbb1000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2aee2dbb1000-2aee2dbb5000 rw-p 2aee2dbb1000 00:00 0
2aee2dbb5000-2aee2dbcb000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2aee2dbcb000-2aee2ddcb000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2aee2ddcb000-2aee2ddcc000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2aee2ddcc000-2aee2debb000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aee2debb000-2aee2e0bb000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aee2e0bb000-2aee2e0c1000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aee2e0c1000-2aee2e0c4000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aee2e0c4000-2aee2e0d8000 rw-p 2aee2e0c4000 00:00 0
2aee2e0d8000-2aee2e158000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2aee2e158000-2aee2e357000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2aee2e357000-2aee2e359000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2aee2e359000-2aee2e366000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2aee2e366000-2aee2e566000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2aee2e566000-2aee2e567000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2aee2e567000-2aee2e6bf000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2aee2e6bf000-2aee2e8bf000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2aee2e8bf000-2aee2e8c2000 r--p 00158000 08:/bin/sh: line 4: 18969 Aborted                 ${dir}$tst
FAIL: obb_test
1 of 1 tests failed
sincerely,
 -The Fathomatic
