[MOAB-dev] buildbot failure in Fathom on moab-shared
    moab-dev at mcs.anl.gov
    Fri Sep  3 00:23:41 CDT 2010
The Fathomatic has detected a failed build of moab-shared on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-shared/builds/219
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason:
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
    major(01): Function arguments
    minor(03): Inappropriate type
  #001: ../../../src/H5I.c line 1257 in H5I_find_id(): invalid ID
    major(07): Atom layer
    minor(32): Unable to find atom information (already closed?)
*** glibc detected *** /disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test: munmap_chunk(): invalid pointer: 0x00000000006b05b0 ***
======= Backtrace: =========
/lib/libc.so.6(cfree+0x1b6)[0x2aadecc33da6]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab12SequenceDataD0Ev+0x45)[0x2aadec0ecfd5]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab19TypeSequenceManager5eraseESt23_Rb_tree_const_iteratorIPNS_14EntitySequenceEE+0xd9)[0x2aadec100709]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab19TypeSequenceManager5eraseEmm+0x11d)[0x2aadec100dfd]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab15SequenceManager15delete_entitiesERKNS_5RangeE+0xbe)[0x2aadec0eeade]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab4Core15delete_entitiesERKNS_5RangeE+0x3e6)[0x2aadec0b1736]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab4Core20clean_up_failed_readERKNS_5RangeESt6vectorIPPvSaIS6_EE+0x76)[0x2aadec0b3646]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab4Core16serial_load_fileEPKcPKmRKNS_11FileOptionsEPKNS_11ReaderIface10SubsetListEPKPPv+0x4ff)[0x2aadec0b765f]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab4Core9load_fileEPKcPKmS2_S2_PKii+0x156)[0x2aadec0b7906]
/disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0(_ZN4moab4Core9load_meshEPKcPKii+0x25)[0x2aadec0ad2b5]
/disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test[0x40618f]
/disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test[0x409999]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2aadecbda1c4]
/disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test(__gxx_personality_v0+0xb9)[0x403089]
======= Memory map: ========
00400000-0040e000 r-xp 00000000 09:00 7570106                            /disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test
0060d000-0060e000 rw-p 0000d000 09:00 7570106                            /disk/itaps-buildslave/moab-shared/build/test/obb/.libs/lt-obb_test
0060e000-006ea000 rw-p 0060e000 00:00 0                                  [heap]
2aadebdf1000-2aadebe0e000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2aadebe0e000-2aadebe11000 rw-p 2aadebe0e000 00:00 0
2aadec00e000-2aadec010000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2aadec010000-2aadec1f4000 r-xp 00000000 09:00 7570003                    /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2aadec1f4000-2aadec3f3000 ---p 001e4000 09:00 7570003                    /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2aadec3f3000-2aadec3fc000 rw-p 001e3000 09:00 7570003                    /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2aadec3fc000-2aadec3fe000 rw-p 2aadec3fc000 00:00 0
2aadec421000-2aadec510000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aadec510000-2aadec710000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aadec710000-2aadec716000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aadec716000-2aadec719000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2aadec719000-2aadec72c000 rw-p 2aadec719000 00:00 0
2aadec72c000-2aadec7ac000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2aadec7ac000-2aadec9ab000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2aadec9ab000-2aadec9ad000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2aadec9ad000-2aadec9ae000 rw-p 2aadec9ad000 00:00 0
2aadec9ae000-2aadec9bb000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2aadec9bb000-2aadecbbb000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2aadecbbb000-2aadecbbc000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2aadecbbc000-2aadecd14000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2aadecd1/bin/sh: line 4: 11834 Aborted                 ${dir}$tst
FAIL: obb_test
1 of 1 tests failed
sincerely,
 -The Fathomatic
