[MOAB-dev] buildbot failure in Fathom on moab-32bit-handles
    moab-dev at mcs.anl.gov
    Fri Sep  3 00:08:54 CDT 2010
The Fathomatic has detected a failed build of moab-32bit-handles on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-32bit-handles/builds/220
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
./obb_test[0x419f34]
./obb_test[0x41a1c9]
./obb_test[0x412163]
./obb_test[0x40a9ef]
./obb_test[0x40e199]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2ae6631011c4]
./obb_test(__gxx_personality_v0+0x1c9)[0x407919]
======= Memory map: ========
00400000-00560000 r-xp 00000000 09:00 7096926                            /disk/itaps-buildslave/moab-32bit-handles/build/test/obb/obb_test
0075f000-00761000 rw-p 0015f000 09:00 7096926                            /disk/itaps-buildslave/moab-32bit-handles/build/test/obb/obb_test
00761000-00822000 rw-p 00761000 00:00 0                                  [heap]
2ae661af1000-2ae661b0e000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2ae661b0e000-2ae661b12000 rw-p 2ae661b0e000 00:00 0
2ae661d0e000-2ae661d10000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2ae661d10000-2ae661d2e000 r-xp 00000000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2ae661d2e000-2ae661f2d000 ---p 0001e000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2ae661f2d000-2ae661f2f000 rw-p 0001d000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2ae661f2f000-2ae661f63000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2ae661f63000-2ae662163000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2ae662163000-2ae662164000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2ae662164000-2ae662166000 rw-p 2ae662164000 00:00 0
2ae662166000-2ae6622fe000 r-xp 00000000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2ae6622fe000-2ae6624fd000 ---p 00198000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2ae6624fd000-2ae662507000 rw-p 00197000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2ae662507000-2ae662515000 rw-p 2ae662507000 00:00 0
2ae662515000-2ae66252b000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2ae66252b000-2ae66272b000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2ae66272b000-2ae66272d000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2ae66272d000-2ae662731000 rw-p 2ae66272d000 00:00 0
2ae662731000-2ae662747000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2ae662747000-2ae662947000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2ae662947000-2ae662948000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2ae662948000-2ae662a37000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2ae662a37000-2ae662c37000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2ae662c37000-2ae662c3d000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2ae662c3d000-2ae662c40000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2ae662c40000-2ae662c54000 rw-p 2ae662c40000 00:00 0
2ae662c54000-2ae662cd4000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2ae662cd4000-2ae662ed3000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2ae662ed3000-2ae662ed5000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2ae662ed5000-2ae662ee2000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2ae662ee2000-2ae6630e2000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2ae6630e2000-2ae6630e3000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2ae6630e3000-2ae66323b000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2ae66323b000-2ae66343b000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2ae66343b000-2ae66343e000 r--p 00158000 08:01 685789                 /bin/sh: line 4: 11211 Aborted                 ${dir}$tst
FAIL: obb_test
1 of 1 tests failed
sincerely,
 -The Fathomatic
