[MOAB-dev] buildbot failure in Fathom on moab-par
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Fri Sep 3 00:05:23 CDT 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/264
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
./obb_test[0x418d22]
./obb_test[0x412603]
./obb_test[0x40adff]
./obb_test[0x40e609]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b4c8faef1c4]
./obb_test(__gxx_personality_v0+0x269)[0x407cf9]
======= Memory map: ========
00400000-008d4000 r-xp 00000000 09:00 39518210                           /disk/itaps-buildslave/moab-par/build/test/obb/obb_test
00ad3000-00ad9000 rw-p 004d3000 09:00 39518210                           /disk/itaps-buildslave/moab-par/build/test/obb/obb_test
00ad9000-00c0f000 rw-p 00ad9000 00:00 0                                  [heap]
2b4c8e684000-2b4c8e6a1000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2b4c8e6a1000-2b4c8e6a5000 rw-p 2b4c8e6a1000 00:00 0
2b4c8e8a1000-2b4c8e8a3000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2b4c8e8a3000-2b4c8e8c1000 r-xp 00000000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b4c8e8c1000-2b4c8eac0000 ---p 0001e000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b4c8eac0000-2b4c8eac2000 rw-p 0001d000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b4c8eac2000-2b4c8eaf6000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b4c8eaf6000-2b4c8ecf6000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b4c8ecf6000-2b4c8ecf7000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b4c8ecf7000-2b4c8ecf9000 rw-p 2b4c8ecf7000 00:00 0
2b4c8ecf9000-2b4c8ed0f000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b4c8ed0f000-2b4c8ef0f000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b4c8ef0f000-2b4c8ef10000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b4c8ef10000-2b4c8ef11000 rw-p 2b4c8ef10000 00:00 0
2b4c8ef11000-2b4c8ef27000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2b4c8ef27000-2b4c8f127000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b4c8f127000-2b4c8f129000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b4c8f129000-2b4c8f12d000 rw-p 2b4c8f129000 00:00 0
2b4c8f12d000-2b4c8f135000 r-xp 00000000 08:01 326577                     /lib/librt-2.7.so
2b4c8f135000-2b4c8f334000 ---p 00008000 08:01 326577                     /lib/librt-2.7.so
2b4c8f334000-2b4c8f336000 rw-p 00007000 08:01 326577                     /lib/librt-2.7.so
2b4c8f336000-2b4c8f425000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b4c8f425000-2b4c8f625000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b4c8f625000-2b4c8f62b000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b4c8f62b000-2b4c8f62e000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b4c8f62e000-2b4c8f642000 rw-p 2b4c8f62e000 00:00 0
2b4c8f642000-2b4c8f6c2000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2b4c8f6c2000-2b4c8f8c1000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2b4c8f8c1000-2b4c8f8c3000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2b4c8f8c3000-2b4c8f8d0000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2b4c8f8d0000-2b4c8fad0000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b4c8fad0000-2b4c8fad1000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b4c8fad1000-2b4c8fc29000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2b4c8fc29000-2b4c8fe29000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2b4c8fe29000-2b4c8fe2c000 r--p 00158000 08:01 685789                     /lib/libc-2.7.so
2b4c8fe2c000-2b4c8fe2e000 rw-p 0015b000 /bin/sh: line 4:  5038 Aborted                 ${dir}$tst
FAIL: obb_test
1 of 1 tests failed
sincerely,
 -The Fathomatic
