[MOAB-dev] buildbot failure in Fathom on moab-serial
    moab-dev at mcs.anl.gov
    Fri Sep  3 00:04:28 CDT 2010
The Fathomatic has detected a failed build of moab-serial on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-serial/builds/263
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
00762000-0083c000 rw-p 00762000 00:00 0                                  [heap]
2b8a415fe000-2b8a4161b000 r-xp 00000000 08:01 685786                     /lib/ld-2.7.so
2b8a4161b000-2b8a4161f000 rw-p 2b8a4161b000 00:00 0
2b8a4181b000-2b8a4181d000 rw-p 0001d000 08:01 685786                     /lib/ld-2.7.so
2b8a4181d000-2b8a4183b000 r-xp 00000000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b8a4183b000-2b8a41a3a000 ---p 0001e000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b8a41a3a000-2b8a41a3c000 rw-p 0001d000 08:01 867111                     /usr/lib/libnetcdf_c++.so.4.0.0
2b8a41a3c000-2b8a41a70000 r-xp 00000000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b8a41a70000-2b8a41c70000 ---p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b8a41c70000-2b8a41c71000 rw-p 00034000 08:01 867110                     /usr/lib/libnetcdf.so.4.0.0
2b8a41c71000-2b8a41c73000 rw-p 2b8a41c71000 00:00 0
2b8a41c73000-2b8a41e0b000 r-xp 00000000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b8a41e0b000-2b8a4200a000 ---p 00198000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b8a4200a000-2b8a42014000 rw-p 00197000 08:01 863635                     /usr/lib/libhdf5-1.6.5.so.0.0.0
2b8a42014000-2b8a42022000 rw-p 2b8a42014000 00:00 0
2b8a42022000-2b8a42038000 r-xp 00000000 08:01 326575                     /lib/libpthread-2.7.so
2b8a42038000-2b8a42238000 ---p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b8a42238000-2b8a4223a000 rw-p 00016000 08:01 326575                     /lib/libpthread-2.7.so
2b8a4223a000-2b8a4223e000 rw-p 2b8a4223a000 00:00 0
2b8a4223e000-2b8a42254000 r-xp 00000000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b8a42254000-2b8a42454000 ---p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b8a42454000-2b8a42455000 rw-p 00016000 08:01 867430                     /usr/lib/libz.so.1.2.3.3
2b8a42455000-2b8a42544000 r-xp 00000000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b8a42544000-2b8a42744000 ---p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b8a42744000-2b8a4274a000 r--p 000ef000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b8a4274a000-2b8a4274d000 rw-p 000f5000 08:01 360647                     /usr/lib/libstdc++.so.6.0.9
2b8a4274d000-2b8a42761000 rw-p 2b8a4274d000 00:00 0
2b8a42761000-2b8a427e1000 r-xp 00000000 08:01 326565                     /lib/libm-2.7.so
2b8a427e1000-2b8a429e0000 ---p 00080000 08:01 326565                     /lib/libm-2.7.so
2b8a429e0000-2b8a429e2000 rw-p 0007f000 08:01 326565                     /lib/libm-2.7.so
2b8a429e2000-2b8a429ef000 r-xp 00000000 08:01 692969                     /lib/libgcc_s.so.1
2b8a429ef000-2b8a42bef000 ---p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b8a42bef000-2b8a42bf0000 rw-p 0000d000 08:01 692969                     /lib/libgcc_s.so.1
2b8a42bf0000-2b8a42d48000 r-xp 00000000 08:01 685789                     /lib/libc-2.7.so
2b8a42d48000-2b8a42f48000 ---p 00158000 08:01 685789                     /lib/libc-2.7.so
2b8a42f48000-2b8a42f4b000 r--p 00158000 08:01 685789                     /lib/libc-2.7.so
2b8a42f4b000-2b8a42f4d000 rw-p 0015b000 08:01 685789                     /lib/libc-2.7.so
2b8a42f4d000-2b8a42f53000 rw-p 2b8a42f4d000 00:00 0
2b8a42f53000-2b8a42f5b000 r-xp 00000000 08:01 326577                     /lib/librt-2.7.so
2b8a42f5b000-2b8a4315a000 ---p 00008000 08:01 326577                     /lib/librt-2.7.so
2b8a4315a000-2b8a4315c000 rw-p 00007000 08:01 326577                     /lib/librt-2.7.so
2b8a4315c000-2b8a4315e000 rw-p 2b8a4315c000 00:00 0
7fff4264f000-7fff42664000 rw-p 7ffffffea000 00:00 0                      [stack]
7fff426f5000-7fff426f7000 r-xp 7fff426f5000 00:00 0                      [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
/bin/sh: line 4: 23141 Aborted                 ${dir}$tst
FAIL: obb_test
1 of 1 tests failed
sincerely,
 -The Fathomatic
