[MOAB-dev] r4116 - MOAB/trunk/test
kraftche at cae.wisc.edu
Wed Sep 1 10:50:59 CDT 2010
Author: kraftche
Date: 2010-09-01 10:50:58 -0500 (Wed, 01 Sep 2010)
New Revision: 4116
Modified:
MOAB/trunk/test/MBTest.cpp
Log:
small portability fix
Modified: MOAB/trunk/test/MBTest.cpp
--- MOAB/trunk/test/MBTest.cpp 2010-08-31 22:51:57 UTC (rev 4115)
+++ MOAB/trunk/test/MBTest.cpp 2010-09-01 15:50:58 UTC (rev 4116)
@@ -125,11 +125,12 @@
// check blocked coordinates
- double x[vertices.size()+1], y[vertices.size()+1], z[vertices.size()+1];
+ const size_t N = vertices.size()+1;
+ std::vector<double> x(N), y(N), z(N);
// set last value so we can check later that nothing wrote past the
// intended end of an array
x[vertices.size()] = y[vertices.size()] = z[vertices.size()] = -3.14159;
- error = MB->get_coords( vertices, x, y, z );
+ error = MB->get_coords( vertices, &x[0], &y[0], &z[0] );
for (size_t i = 0; i < vertices.size(); ++i) {
CHECK_EQUAL( all_coords[3*i ], x[i] );
CHECK_EQUAL( all_coords[3*i+1], y[i] );
@@ -142,14 +143,14 @@
// add invalid handle to end of range and try query again
vertices.insert( vertices.back() + 1 );
CHECK_EQUAL( MB_ENTITY_NOT_FOUND, error );
// Try getting coordinates for a hex (should fail)
Range hexes;
error = MB->get_entities_by_type( 0, MBHEX, hexes );
EntityHandle handle = hexes.front();
- error = MB->get_coords(&handle, 1, x);
+ error = MB->get_coords(&handle, 1, &x[0]);
CHECK_EQUAL( MB_TYPE_OUT_OF_RANGE, error );
return MB_SUCCESS;
