[MOAB-dev] r4117 - in MOAB/trunk: test test/io tools
    kraftche at cae.wisc.edu
    Wed Sep  1 10:52:27 CDT 2010
Author: kraftche
Date: 2010-09-01 10:52:27 -0500 (Wed, 01 Sep 2010)
New Revision: 4117
Modified:
   MOAB/trunk/test/Makefile.am
   MOAB/trunk/test/io/Makefile.am
   MOAB/trunk/tools/Makefile.am
Log:
fix distcheck failure and remove unnecessary _DEPENDENCIES lines for test and tool targets
Modified: MOAB/trunk/test/Makefile.am
--- MOAB/trunk/test/Makefile.am	2010-09-01 15:50:58 UTC (rev 4116)
+++ MOAB/trunk/test/Makefile.am	2010-09-01 15:52:27 UTC (rev 4117)
@@ -67,52 +67,24 @@
 homxform_test_SOURCES = $(top_srcdir)/src/HomXform.cpp
 homxform_test_CPPFLAGS = -DTEST $(AM_CPPFLAGS) $(CPPFLAGS)
-homxform_test_DEPENDENCIES = $(LDADD)
 scdseq_test_SOURCES = scdseq_test.cpp
-scdseq_test_DEPENDENCIES = $(LDADD)
 #scdseq_timing_SOURCES = scdseq_timing.cpp
-#scdseq_timing_DEPENDENCIES = $(LDADD)
 #merge_test_SOURCES = merge_test.cpp
-#merge_test_DEPENDENCIES = $(LDADD)
 #test_exo_SOURCES = test_exo.cpp
-#test_exo_DEPENDENCIES = $(LDADD)
 #test_tag_server_SOURCES = $(top_srcdir)/src/TagServer.cpp
 #test_tag_server_CPPFLAGS = -DTEST $(CPPFLAGS)
-#test_tag_server_DEPENDENCIES = $(LDADD)
 test_adj_SOURCES = test_adj.cpp
-test_adj_DEPENDENCIES = $(LDADD)
 seq_man_test_SOURCES = TestUtil.hpp TestTypeSequenceManager.cpp
 mesh_set_test_SOURCES = Test_MBMeshSet.cpp TestUtil.hpp
 geom_util_test_SOURCES = TestUtil.hpp GeomUtilTests.cpp
-geom_util_test_DEPENDENCIES = $(LDADD)
 xform_test_SOURCES = $(top_srcdir)/src/AffineXform.cpp
-xform_test_DEPENDENCIES = $(LDADD)
 obb_test_SOURCES = OBBTest.cpp
-obb_test_DEPENDENCIES = $(LDADD)
 adaptive_kd_tree_tests_SOURCES = adaptive_kd_tree_tests.cpp
-adaptive_kd_tree_tests_DEPENDENCIES = $(LDADD)
 kd_tree_tool_SOURCES = kd_tree_tool.cpp
-kd_tree_tool_DEPENDENCIES = $(LDADD)
 kd_tree_time_SOURCES = kd_tree_time.cpp
-kd_tree_time_DEPENDENCIES = $(LDADD)
