[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Wed Sep 1 00:15:22 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/254
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
test -z "libmoabio.la " || rm -f libmoabio.la
rm -f "./so_locations"
rm -f *.o
rm -f *.lo
rm -f *.tab.c
test -z "" || rm -f
rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
rm -rf ./.deps
rm -f Makefile
Making distclean in parallel
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/src/parallel'
rm -rf .libs _libs
test -z "libMOABpar.la" || rm -f libMOABpar.la
rm -f *.o
rm -f *.lo
rm -f *.tab.c
test -z "" || rm -f
rm -f moab_mpi_config.h stamp-h4
rm -rf ./.deps
rm -f Makefile
Making distclean in .
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/src'
test -z "libMOAB.la " || rm -f libMOAB.la
rm -rf .libs _libs
rm -f *.o
test -z "MOAB_FCDefs.h" || rm -f MOAB_FCDefs.h
rm -f *.lo
rm -f *.tab.c
test -z "" || rm -f
rm -f FCDefs.h stamp-h5
rm -rf ./.deps
rm -f Makefile
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build'
test -z "moab.config" || rm -f moab.config
rm -rf .libs _libs
rm -f *.lo
test -z "moab.make examples/simple/makefile" || rm -f moab.make examples/simple/makefile
rm -f config.h stamp-h1 src/moab/Version.h src/moab/stamp-h2 src/moab/EntityHandle.hpp src/moab/stamp-h3
rm -f libtool
rm -f config.status config.cache config.log configure.lineno config.status.lineno
rm -f Makefile
ERROR: files left in build directory after distclean:
./test/io/mb_write.g
./test/io/mb_write2.g
sincerely,
 -The Fathomatic
