[MOAB-dev] question on ddd
    iulian at mcs.anl.gov
    Fri Aug 20 09:52:23 CDT 2010
Hello,
If you are on Ubuntu 10.04, and if you use ddd, you may have encountered this bug, for which the
mouse is trapped, and x server is locked (when you use a right click in the data window)
I do not understand what is the solution, (patch?). I know Rajeev experienced this problem back in May.
https://bugs.launchpad.net/ubuntu/+source/ddd/+bug/574157
http://bugs.freedesktop.org/show_bug.cgi?id=25400
Do you have any solution?
Iulian
