[MOAB-dev] cgm2moab as a script
Tim Tautges tautges at mcs.anl.gov
Thu Aug 19 12:52:52 CDT 2010
On 08/19/2010 12:31 PM, Paul Wilson wrote:
>   Hi Tim,
> But this raises questions about what "should" be in a reader and what
> shouldn't. Do we want the CGM reader to include options that are
> specific to DAGMC users? It seems that the following aren't strictly
> functions of a reader:
>     * OBB tree generation
>     * Implicit complement generation
>     * Graveyard removal/suppression
Correct; I'd been going on your statement about using it for things other than strictly dagmc pre-processing.
- tim
> Paul
> On 8/19/2010 4:03 PM, Tim Tautges wrote:
>> But these should all be enabled by options to things like mbconvert,
>> maybe not now, but eventually (since the faceting options to cgm2moab
>> get passed to the cgm reader ultimately).
>> - tim
>> On 08/19/2010 04:13 AM, Paul Wilson wrote:
>>> Hi Steve,
>>> One reason to use cgm2moab other than strictly for dagmc pre-processing
>>> is to generate a mesh-based geometry representation for visualization
>>> (e.g. in VisIt). This use case will probably make use of any faceting
>>> controls that are exposed in cgm2moab but does NOT require OBB/implicit
>>> complement processing. (... and ideally, will remove the graveyard, but
>>> that should be taken care of by subset manipulations in VisIt,
>>> hopefully).
>>> Paul
>>> On 8/17/2010 10:19 PM, Steve Jackson wrote:
>>>> (Note to all: if you use cgm2moab, please read the last paragraph of
>>>> this message.)
>>>> On Aug 17, 2010, at 14:18 , Jason Kraftcheck wrote:
>>>>> Why do you want to make this change at all? Is there any active
>>>>> development
>>>>> on cgm2moab that would be made easier?
>>>> It wouldn't greatly improve the lives of developers in the short term.
>>>> The chief reason to go to a script would be to simplify the code base.
>>>> All else being equal, it's better to have dozens of lines of script
>>>> instead of hundreds of lines of c++. I agree, though, that it's not
>>>> worth introducing a whole scripting setup for MOAB just for this minor
>>>> utility.
>>>>> Should we just remove the utility? Is it frequently used? It is a lot
>>>>> simpler to use a more specialized utility as opposed to mbconvert,
>>>>> but is
>>>>> there a sufficient number of users to justify maintaining such a
>>>>> utility in
>>>>> MOAB, installing it for all users, etc. as opposed to just letting
>>>>> users
>>>>> write their own wrapper script?
>>>> To my knowledge, its chief (only?) use in practice is to preprocess
>>>> CAD data for use by dagmc.
>>>> Paul and I have discussed extending cgm2moab to optionally do even
>>>> more preprocessing for dagmc (e.g. build and save the OBB tree
>>>> structures, a slow process normally done when dagmc is initialized).
>>>> If we decide to do this, then the question of using a scripting
>>>> language becomes moot, because the new features would require C++. But
>>>> if we do this, then 'cgm2moab' becomes something of a misnomer; I'd be
>>>> tempted to call the program 'dagmc_prep' or similar.
>>>> It would be useful to know if anyone is using cgm2moab for purposes
>>>> *other* than dagmc preprocessing. If not, perhaps it should be renamed
>>>> and repurposed as a dagmc preprocessing tool.
>>>> ~S
> Paul Wilson
> Paul P.H. Wilson              419 Engineering Research Building
> wilsonp at engr.wisc.edu                        1500 Engineering Dr
> ph/fax: 608/263-0807                          Madison, WI 53706
>             My calendar:http://bit.ly/pphw-calendar
>         Computational Nuclear Engineering Research Group
>                 http://cnerg.engr.wisc.edu
>            Associate Professor, Nuclear Engineering
>                Engineering Physics Department
>                 http://www.engr.wisc.edu/ep
>          Chair, Energy Analysis&  Policy Certificate
>           Nelson Institute for Environmental Studies
>                  http://nelson.wisc.edu/eap/
>            Contributing to the joy and improvement
>                    of all those around me
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
