[MOAB-dev] r4107 - in MOAB/trunk: doc itaps/imesh src src/io src/moab
tautges at mcs.anl.gov
Fri Aug 20 17:54:53 CDT 2010
Author: tautges
Date: 2010-08-20 17:54:53 -0500 (Fri, 20 Aug 2010)
New Revision: 4107
Modified:
MOAB/trunk/doc/metadata_info.doc
MOAB/trunk/itaps/imesh/iMesh.h
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/src/io/ReadNC.hpp
MOAB/trunk/src/io/WriteCCMIO.cpp
MOAB/trunk/src/moab/Interface.hpp
Log:
io/ReadNC.?pp: adding a bit more NC reader code
io/WriteCCMIO.cpp: account for case where no material sets have been created
doc/metadata_info.doc: small additions, for CCMIO file metadata and parallel status
Core.cpp: changes to allow range-based deletion of entities, for efficiency
Interface.hpp: adding \mainpage section to comments
Passes make check in serial and parallel.
Modified: MOAB/trunk/doc/metadata_info.doc
(Binary files differ)
Modified: MOAB/trunk/itaps/imesh/iMesh.h
--- MOAB/trunk/itaps/imesh/iMesh.h 2010-08-18 21:07:01 UTC (rev 4106)
+++ MOAB/trunk/itaps/imesh/iMesh.h 2010-08-20 22:54:53 UTC (rev 4107)
@@ -13,7 +13,7 @@
* to this interface, for example mesh smoothing, adaptive mesh refinement,
* and parallel mesh support.
- * \section ITAPS Data Model
+ * \section DataModel Data Model
* The ITAPS interfaces use a data model composed of four basic data types: \n
* \em Entity: basic topological entities in a mesh, e.g. vertices,
@@ -37,14 +37,14 @@
* types, Entity Type in the iBase_EntityType enumeration, and
* Entity Topology in the iMesh_EntityTopology enumeration.
- * \section KTAPS Entity-, Array-, and Iterator-Based Access
+ * \section Access Entity-, Array-, and Iterator-Based Access
* The iMesh interface provides functions for accessing entities
* individually, as arrays of entities, or using iterators. These access
* methods have different memory versus execution time tradeoffs,
* depending on the implementation.
- * \section LTAPS Lists Passed Through Interface
+ * \section Lists Lists Passed Through Interface
* Many of the functions in iMesh have arguments corresponding to lists of
* objects. In-type arguments for lists consist of a pointer to an array and
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2010-08-18 21:07:01 UTC (rev 4106)
+++ MOAB/trunk/src/Core.cpp 2010-08-20 22:54:53 UTC (rev 4107)
@@ -2183,6 +2183,7 @@
ErrorCode Core::delete_entities(const Range &range)
ErrorCode result = MB_SUCCESS, temp_result;
+ Range failed_ents;
for (Range::const_reverse_iterator rit = range.rbegin(); rit != range.rend(); rit++) {
@@ -2190,6 +2191,7 @@
temp_result = aEntityFactory->notify_delete_entity(*rit);
if (MB_SUCCESS != temp_result) {
result = temp_result;
