[MOAB-dev] r4018 - MOAB/trunk/src/io
Rajeev Jain
jain at mcs.anl.gov
Fri Jun 25 14:41:18 CDT 2010
Compress usually isn't a problem, but I thought it would be better to be
safe and have it works always; at some cost.
You are right, there are no errors, but the o/p is not right. Some hexes
have become polyhedra's, as you pointed out that we have cell bounded by
the wrong # of faces.
May be we need another function for writing neusets with internal faces?
Rajeev
On 06/25/2010 02:26 PM, Tim Tautges wrote:
> On 06/25/2010 02:22 PM, jain at mcs.anl.gov wrote:
>> Author: jain
>> Date: 2010-06-25 14:22:48 -0500 (Fri, 25 Jun 2010)
>> New Revision: 4018
>> Modified:
>> MOAB/trunk/src/io/WriteCCMIO.cpp
>> Log:
>> o Commented CCMIOCompress
> You shouldn't do this, the compress usually isn't the problem.
>> o Skipping empty neumann sets when writing external faces
>> o Commented the check for internal faces in write_external_faces
>> function, since neumann sets can have internal faces
> You should also not do this; just because the check isn't done doesn't
> mean the write will be correct (in this case, you'll have a cell
> bounded by the wrong # of faces).
> - tim
>> Modified: MOAB/trunk/src/io/WriteCCMIO.cpp
>> --- MOAB/trunk/src/io/WriteCCMIO.cpp 2010-06-24 11:31:05 UTC (rev
>> 4017)
>> +++ MOAB/trunk/src/io/WriteCCMIO.cpp 2010-06-25 19:22:48 UTC (rev
>> 4018)
>> @@ -330,8 +330,8 @@
>> // to call CCMIOCompress() here to ensure that the file is as
>> small as
>> // possible. Please see the Core API documentation for caveats
>> on its
>> // usage.
>> - CCMIOCompress(&error, const_cast<char*>(filename));
>> - CHKCCMERR(error, "Error compressing file.");
>> + // CCMIOCompress(&error, const_cast<char*>(filename));
>> + // CHKCCMERR(error, "Error compressing file.");
>> return MB_SUCCESS;
>> @@ -1203,6 +1203,10 @@
>> CCMIONewEntity(&error, rootID, kCCMIOMap, NULL,&mapID);
>> CHKCCMERR(error, "Problem creating face id map.");
>> + // ignoring an empty neuset, just return
>> + if(facets.size()==0)
>> + return MB_SUCCESS;
>> CCMIOWriteMap(&error, mapID, CCMIOSIZEC(facets.size()),
>> CCMIOSIZEC(maxid), gids,
>> CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
>> @@ -1254,8 +1258,9 @@
>> result = mbImpl->tag_get_data(mEntityMark,&cells[0],
>> cells.size(), cmarks);
>> CHKERR(result, "Trouble getting mark tags on cells bounding
>> facets.");
>> if (cells.size() == 2&& (mWholeMesh || (cmarks[0]&&
>> cmarks[1]))) {
>> - result = MB_FILE_WRITE_ERROR;
>> - CHKERR(result, "External facet with two output bounding cells.");
>> + // commenting since neuset_data can have internal faces
>> + // result = MB_FILE_WRITE_ERROR;
>> + // CHKERR(result, "External facet with two output bounding
>> cells.");
>> else if (1 == cells.size()&& !mWholeMesh&& !cmarks[0]) {
Rajeev
