[MOAB-dev] r4019 - MOAB/trunk/src/io
jain at mcs.anl.gov jain at mcs.anl.gov
Fri Jun 25 17:41:23 CDT 2010
Author: jain
Date: 2010-06-25 17:41:23 -0500 (Fri, 25 Jun 2010)
New Revision: 4019
Modified:
   MOAB/trunk/src/io/WriteCCMIO.cpp
Log:
o Opening compress again..
o Filtering out the faces with 2 adjacent elements before calling write_external_faces
Modified: MOAB/trunk/src/io/WriteCCMIO.cpp
--- MOAB/trunk/src/io/WriteCCMIO.cpp	2010-06-25 19:22:48 UTC (rev 4018)
+++ MOAB/trunk/src/io/WriteCCMIO.cpp	2010-06-25 22:41:23 UTC (rev 4019)
@@ -330,8 +330,8 @@
     // to call CCMIOCompress() here to ensure that the file is as small as
     // possible.  Please see the Core API documentation for caveats on its
     // usage.
-  // CCMIOCompress(&error, const_cast<char*>(filename));
-  // CHKCCMERR(error, "Error compressing file.");
+  CCMIOCompress(&error, const_cast<char*>(filename));
+  CHKCCMERR(error, "Error compressing file.");
   return MB_SUCCESS;
@@ -968,9 +968,31 @@
     // write external faces
   for (unsigned int i = 0; i < neuset_data.size(); i++) {
-    result = write_external_faces(rootID, topologyID, neuset_data[i].neusetId,
-                                  neuset_data[i].elems);
+    Range::reverse_iterator rit;
+    unsigned char cmarks[2];
+    Range ext_faces;
+    std::vector<EntityHandle> cells;
+    // removing the faces connected to two regions
+    for (rit = neuset_data[i].elems.rbegin(); rit != neuset_data[i].elems.rend(); ++rit) {
+      cells.clear();
+      result = mbImpl->get_adjacencies(&(*rit), 1, mDimension, false, cells);
+      CHKERR(result, "Trouble getting bounding cells.");
+      result = mbImpl->tag_get_data(mEntityMark, &cells[0], cells.size(), cmarks);
+      CHKERR(result, "Trouble getting mark tags on cells bounding facets.");
+      if( cells.size() == 2 && (mWholeMesh || (cmarks[0] && cmarks[1]))) {
+      else{
+	// external face
+	ext_faces.insert(*rit);
+    if (ext_faces.size() != 0)
+      result = write_external_faces(rootID, topologyID, neuset_data[i].neusetId,
+				    ext_faces);
     CHKERR(result, "Trouble writing Neumann set facets.");
+    ext_faces.clear ();
   if (!skin_facets.empty()) {
@@ -1203,10 +1225,6 @@
   CCMIONewEntity(&error, rootID, kCCMIOMap, NULL, &mapID);
