[MOAB-dev] r4018 - MOAB/trunk/src/io
Tim Tautges
tautges at mcs.anl.gov
Fri Jun 25 14:26:49 CDT 2010
On 06/25/2010 02:22 PM, jain at mcs.anl.gov wrote:
> Author: jain
> Date: 2010-06-25 14:22:48 -0500 (Fri, 25 Jun 2010)
> New Revision: 4018
> Modified:
> MOAB/trunk/src/io/WriteCCMIO.cpp
> Log:
> o Commented CCMIOCompress
You shouldn't do this, the compress usually isn't the problem.
> o Skipping empty neumann sets when writing external faces
> o Commented the check for internal faces in write_external_faces function, since neumann sets can have internal faces
You should also not do this; just because the check isn't done doesn't mean the write will be correct (in this case,
you'll have a cell bounded by the wrong # of faces).
- tim
> Modified: MOAB/trunk/src/io/WriteCCMIO.cpp
> --- MOAB/trunk/src/io/WriteCCMIO.cpp 2010-06-24 11:31:05 UTC (rev 4017)
> +++ MOAB/trunk/src/io/WriteCCMIO.cpp 2010-06-25 19:22:48 UTC (rev 4018)
> @@ -330,8 +330,8 @@
> // to call CCMIOCompress() here to ensure that the file is as small as
> // possible. Please see the Core API documentation for caveats on its
> // usage.
> - CCMIOCompress(&error, const_cast<char*>(filename));
> - CHKCCMERR(error, "Error compressing file.");
> + // CCMIOCompress(&error, const_cast<char*>(filename));
> + // CHKCCMERR(error, "Error compressing file.");
> return MB_SUCCESS;
> @@ -1203,6 +1203,10 @@
> CCMIONewEntity(&error, rootID, kCCMIOMap, NULL,&mapID);
> CHKCCMERR(error, "Problem creating face id map.");
> + // ignoring an empty neuset, just return
> + if(facets.size()==0)
> + return MB_SUCCESS;
> CCMIOWriteMap(&error, mapID, CCMIOSIZEC(facets.size()),
> CCMIOSIZEC(maxid), gids,
> CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOEnd));
> @@ -1254,8 +1258,9 @@
> result = mbImpl->tag_get_data(mEntityMark,&cells[0], cells.size(), cmarks);
> CHKERR(result, "Trouble getting mark tags on cells bounding facets.");
> if (cells.size() == 2&& (mWholeMesh || (cmarks[0]&& cmarks[1]))) {
> - result = MB_FILE_WRITE_ERROR;
> - CHKERR(result, "External facet with two output bounding cells.");
> + // commenting since neuset_data can have internal faces
> + // result = MB_FILE_WRITE_ERROR;
> + // CHKERR(result, "External facet with two output bounding cells.");
> else if (1 == cells.size()&& !mWholeMesh&& !cmarks[0]) {
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
