[MOAB-dev] r3994 - in MOAB/trunk: . src/io
kraftche at cae.wisc.edu
Wed Jun 2 15:14:50 CDT 2010
Author: kraftche
Date: 2010-06-02 15:14:49 -0500 (Wed, 02 Jun 2010)
New Revision: 3994
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/src/io/ReadHDF5.cpp
Log:
fix large file support on 32-bit machines (e.g. BGP). you'll need to do 'make clean' and rebuild for this change to take effect
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2010-06-02 20:14:05 UTC (rev 3993)
+++ MOAB/trunk/configure.ac 2010-06-02 20:14:49 UTC (rev 3994)
@@ -52,7 +52,13 @@
AC_CHECK_FUNC([vsnprintf],[AM_CPPFLAGS="$AM_CPPFLAGS -DHAVE_VSNPRINTF"])
+# Use 64-bit off_t value for file offsets. W/out this, the stat/fseek calls
+# in serial_open_file and other places will fail on 32-bit systems if the file
+# is larger that 2GB.
+AM_CPPFLAGS="$AM_CPPFLAGS -D_FILE_OFFSET_BITS=64"
# No-Namepsace (3.0) Headers
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2010-06-02 20:14:05 UTC (rev 3993)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2010-06-02 20:14:49 UTC (rev 3994)
@@ -58,12 +58,6 @@
#define READ_HDF5_BUFFER_SIZE (40*1024*1024)
-#if !defined(WIN32) && !defined(WIN64)
-# include <sys/stat.h>
-# include <unistd.h>
-# include <errno.h>
-#endif
#define assert_range( PTR, CNT ) \
assert( (PTR) >= (void*)dataBuffer ); assert( ((PTR)+(CNT)) <= (void*)(dataBuffer + bufferSize) );
@@ -300,20 +294,6 @@
else {
- // first check if file exists, so we can fail w/out
- // a lot of noise from the HDF5 library if it does not
- struct stat stat_info;
- if (stat( filename, &stat_info)) {
- if (ENOENT == errno)
- return MB_FILE_DOES_NOT_EXIST;
- else
- return MB_FILE_WRITE_ERROR;
- else if (S_ISDIR(stat_info.st_mode))
