[MOAB-dev] Order of entities in unordered entity sets?
    James Porter
    jvporter at wisc.edu
    Wed Jun  2 15:30:00 CDT 2010
Sorry, I forgot to save the test file. This should be the correct
version.
- Jim
On Wed, 2010-06-02 at 14:29 -0500, James Porter wrote:
> Attached is a test case that creates an unordered entity set that
> somehow has duplicates in it. Apologies for the complicated selection
> code, but I'm having a hard time reducing it without hiding the bug.
> This program should be run with tjunc6.cub, available here:
> <https://mywebspace.wisc.edu/jvporter/web/tjunc6.cub>. It's possible I'm
> just doing something wrong, but if I am, CopyMesh is probably doing it
> wrong too (unless my selection code is messed up).
> Quick rundown of what the code does: I select the faces of Neumann set
> 100 and the edges adjacent to those faces which are also in Neumann set
> 500. Then I check how many total vertices are used by all that (this is
> the first 3 lines of output).
> The rest of the code is mimicking CopyMesh. First, I add the faces/edges
> to an unordered set. Next, for N=1,2,3 I get the N-D entities back out
> of the set, get the adjacent verts, and add them to the set. Somehow,
> during this, a handful of vertices end up with duplicates in the set.
> Here's the output I get when I run it:
> # edges/faces = 256
> # adj verts = 960
> # unique adj verts = 241
> Total # entities = 514
> Should be = 497
> Duplicates:
>   0xbed
>   0xbee
>   0x19ff
>   0x1a0b
>   0x1a16
>   0x1a17
>   0x1a56
>   0x1a57
>   0x2554
>   0x2555
>   0x2556
>   0x2557
>   0x2558
>   0x2559
>   0x255a
>   0x255b
>   0x255c
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100602/9a84c723/attachment.cpp>
