[MOAB-dev] r3993 - MOAB/trunk/tools
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed Jun 2 15:14:05 CDT 2010
Author: kraftche
Date: 2010-06-02 15:14:05 -0500 (Wed, 02 Jun 2010)
New Revision: 3993
Modified:
   MOAB/trunk/tools/surfplot.cpp
Log:
add option to plot entire mesh to mbsurfplot util
Modified: MOAB/trunk/tools/surfplot.cpp
--- MOAB/trunk/tools/surfplot.cpp	2010-06-02 20:00:30 UTC (rev 3992)
+++ MOAB/trunk/tools/surfplot.cpp	2010-06-02 20:14:05 UTC (rev 3993)
@@ -21,7 +21,7 @@
     << "\t-g           -  Write GNU Plot data file (default)." << std::endl
     << "\t-p           -  Write encapsulated postscript file"  << std::endl
     << "\t-s           -  Write an SVG file"                   << std::endl
-    << "\t<Surface_ID> -  ID of surface containing mesh to export." << std::endl
+    << "\t<Surface_ID> -  ID of surface containing mesh to export (0 for entire file)." << std::endl
     << "\t<input_file> -  Mesh file to read." << std::endl
     << std::endl
     << "  This utility plots the mesh of a single geometric surface "
@@ -199,7 +199,7 @@
     usage_error(argv[0]);
   char* endptr;
   surface_id = strtol( argv[idx], &endptr, 0 );
-  if (!endptr || *endptr || surface_id < 1)
+  if (!endptr || *endptr)
   ++idx;
@@ -214,32 +214,38 @@
     // Get tag handles
-  Tag tags[2];
-  result = moab->tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] );
-  if (MB_SUCCESS != result) {
-    std::cerr << "No geometry tag.\n";
-    return OTHER_ERROR;
+  EntityHandle surface;
+  const int dimension = 2; // surface
+  if (surface_id) {
+    Tag tags[2];
+    result = moab->tag_get_handle( GEOM_DIMENSION_TAG_NAME, tags[0] );
+    if (MB_SUCCESS != result) {
+      std::cerr << "No geometry tag.\n";
+      return OTHER_ERROR;
+    result = moab->tag_get_handle( GLOBAL_ID_TAG_NAME, tags[1] );
+      std::cerr << "No ID tag.\n";
+      // Find entityset for surface.
+    const void* tag_values[] = { &dimension, &surface_id };
+    Range surfaces;
+    moab->get_entities_by_type_and_tag( 0, MBENTITYSET,
+                                        tags, tag_values,
