[MOAB-dev] MOAB on OS X
    acaceres at mcs.anl.gov
    Wed May 12 10:59:10 CDT 2010
I get the same behavior (moab builds ok), and have updated the ticket... I suspect this doesn't fix the problem on Leopard though, still trying to track down a machine to test it.
----- Original Message -----
To: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
Cc: "Developer correspondence for MOAB" <moab-dev at lists.mcs.anl.gov>
Sent: Tuesday, May 11, 2010 7:36:16 PM GMT -06:00 US/Canada Central
Subject: Re: [MOAB-dev] MOAB on OS X
On May 11, 2010, at 18:12 , Jason Kraftcheck wrote:
> I think I see the misunderstanding.  The 'CC' in the above command is the
> actual 'CC' command, not the value of the variable $CC.  'CC' is typically
> the default C++ compiler on most systems.  On linux systems it is usually a
> symlink to g++.
Ah, good catch.  On OSX, CC is a symlink to gcc, rather than to g++.
> What happens if you configure with CXX=g++?
MOAB builds successfully.
~S
