[MOAB-dev] MOAB on OS X
Steve Jackson
sjackson at cae.wisc.edu
Tue May 11 19:36:16 CDT 2010
On May 11, 2010, at 18:12 , Jason Kraftcheck wrote:
> I think I see the misunderstanding. The 'CC' in the above command is the
> actual 'CC' command, not the value of the variable $CC. 'CC' is typically
> the default C++ compiler on most systems. On linux systems it is usually a
> symlink to g++.
Ah, good catch. On OSX, CC is a symlink to gcc, rather than to g++.
> What happens if you configure with CXX=g++?
MOAB builds successfully.
~S
