[MOAB-dev] r3884 - MOAB/trunk/config
kraftche at cae.wisc.edu
Wed May 12 12:49:27 CDT 2010
Author: kraftche
Date: 2010-05-12 12:49:27 -0500 (Wed, 12 May 2010)
New Revision: 3884
Modified:
MOAB/trunk/config/compiler.m4
Log:
o Use default compiler list provided by autoconf
- fixes MAC configure issue
- typically results in selection of g++ over vendor compiler
(e.g. xlC) when both are available. Use CXX= and CC= to
force vendor compiler if necessary
o When compiler is mpicxx, autoconf sometimes fails to identify
it as g++. Add our own checks for g++.
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4 2010-05-12 01:01:23 UTC (rev 3883)
+++ MOAB/trunk/config/compiler.m4 2010-05-12 17:49:27 UTC (rev 3884)
@@ -54,10 +54,10 @@
[WITH_MPI=$withval],[WITH_MPI=no] )
case "x$WITH_MPI" in
xno)
- CC_LIST="cc gcc cl egcs pgcc"
- CXX_LIST="CC aCC cxx xlC_r xlC c++ g++ pgCC gpp cc++ cl FCC KCC RCC"
- FC_LIST="gfortran ifort pgf90"
- F77_LIST="gfortran ifort pgf77"
+ CC_LIST=
+ CXX_LIST=
+ FC_LIST=
+ F77_LIST=
xyes)
CC_LIST="mpicc mpcc"
@@ -111,16 +111,32 @@
esac
if test "xno" != "x$CHECK_CC"; then
- AC_PROG_CC( [$CC_LIST] )
+ if test "x" = "x$CC_LIST"; then
+ AC_PROG_CC
+ else
+ AC_PROG_CC( [$CC_LIST] )
+ fi
fi
AC_PROG_CPP
if test "xno" != "x$CHECK_CXX"; then
- AC_PROG_CXX( [$CXX_LIST] )
+ if test "x" = "x$CXX_LIST"; then
+ AC_PROG_CXX
+ else
+ AC_PROG_CXX( [$CXX_LIST] )
+ fi
AC_PROG_CXXCPP
fi
if test "xno" != "x$CHECK_FC"; then
- AC_PROG_FC( [$FC_LIST] )
- AC_PROG_F77( [$F77_LIST] )
+ if test "x" = "x$FC_LIST"; then
+ AC_PROG_FC
+ else
+ AC_PROG_FC( [FC_LIST] )
+ fi
+ if test "x" = "x$F77_LIST"; then
+ AC_PROG_F77
+ else
