[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Sat May  8 00:13:44 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/143
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
mv -f .deps/Tqdcfr.Tpo .deps/Tqdcfr.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF .deps/VtkUtil.Tpo -c -o VtkUtil.lo ../../../src/io/VtkUtil.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF .deps/VtkUtil.Tpo -c ../../../src/io/VtkUtil.cpp -o VtkUtil.o
mv -f .deps/VtkUtil.Tpo .deps/VtkUtil.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c -o WriteAns.lo ../../../src/io/WriteAns.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c ../../../src/io/WriteAns.cpp -o WriteAns.o
mv -f .deps/WriteAns.Tpo .deps/WriteAns.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c -o WriteGMV.lo ../../../src/io/WriteGMV.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c ../../../src/io/WriteGMV.cpp -o WriteGMV.o
mv -f .deps/WriteGMV.Tpo .deps/WriteGMV.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c -o WriteGmsh.lo ../../../src/io/WriteGmsh.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c ../../../src/io/WriteGmsh.cpp -o WriteGmsh.o
mv -f .deps/WriteGmsh.Tpo .deps/WriteGmsh.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c -o WriteSTL.lo ../../../src/io/WriteSTL.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c ../../../src/io/WriteSTL.cpp -o WriteSTL.o
mv -f .deps/WriteSTL.Tpo .deps/WriteSTL.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteSmf.lo -MD -MP -MF .deps/WriteSmf.Tpo -c -o WriteSmf.lo ../../../src/io/WriteSmf.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteSmf.lo -MD -MP -MF .deps/WriteSmf.Tpo -c ../../../src/io/WriteSmf.cpp -o WriteSmf.o
mv -f .deps/WriteSmf.Tpo .deps/WriteSmf.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c -o WriteTemplate.lo ../../../src/io/WriteTemplate.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c ../../../src/io/WriteTemplate.cpp -o WriteTemplate.o
mv -f .deps/WriteTemplate.Tpo .deps/WriteTemplate.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c -o WriteVtk.lo ../../../src/io/WriteVtk.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c ../../../src/io/WriteVtk.cpp -o WriteVtk.o
mv -f .deps/WriteVtk.Tpo .deps/WriteVtk.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c -o ReadNCDF.lo ../../../src/io/ReadNCDF.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c ../../../src/io/ReadNCDF.cpp -o ReadNCDF.o
mv -f .deps/ReadNCDF.Tpo .deps/ReadNCDF.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c -o WriteNCDF.lo ../../../src/io/WriteNCDF.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c ../../../src/io/WriteNCDF.cpp -o WriteNCDF.o
mv -f .deps/WriteNCDF.Tpo .deps/WriteNCDF.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c -o WriteSLAC.lo ../../../src/io/WriteSLAC.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c ../../../src/io/WriteSLAC.cpp -o WriteSLAC.o
mv -f .deps/WriteSLAC.Tpo .deps/WriteSLAC.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c -o ReadHDF5.lo ../../../src/io/ReadHDF5.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c ../../../src/io/ReadHDF5.cpp -o ReadHDF5.o
mv -f .deps/ReadHDF5.Tpo .deps/ReadHDF5.Plo
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c -o WriteHDF5.lo ../../../src/io/WriteHDF5.cpp
 c++ -DHAVE_CONFIG_H -I. -I../../../src/io -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I../../../src/io/.. -I../../../src/io/../parallel -I../../../src/io/mhdf/include -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c ../../../src/io/WriteHDF5.cpp -o WriteHDF5.o
mv -f .deps/WriteHDF5.Tpo .deps/WriteHDF5.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -O2 -DNDEBUG   -o libmoabio.la  IODebugTrack.lo ExoIIUtil.lo FileTokenizer.lo GmshUtil.lo ReadABAQUS.lo ReadGmsh.lo ReadIDEAS.lo ReadMCNP5.lo ReadNASTRAN.lo ReadSmf.lo ReadSms.lo ReadSTL.lo ReadTetGen.lo ReadVtk.lo SMF_State.lo Tqdcfr.lo VtkUtil.lo WriteAns.lo WriteGMV.lo WriteGmsh.lo WriteSTL.lo WriteSmf.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo   -lnetcdf_c++ -lnetcdf -lhdf5  mhdf/libmhdf.la   -lm
mkdir .libs
rm -fr .libs/libmoabio.lax
mkdir .libs/libmoabio.lax
rm -fr .libs/libmoabio.lax/libmhdf.a
mkdir .libs/libmoabio.lax/libmhdf.a
(cd .libs/libmoabio.lax/libmhdf.a && ar x /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/src/io/mhdf/.libs/libmhdf.a)
ar cru .libs/libmoabio.a  IODebugTrack.o ExoIIUtil.o FileTokenizer.o GmshUtil.o ReadABAQUS.o ReadGmsh.o ReadIDEAS.o ReadMCNP5.o ReadNASTRAN.o ReadSmf.o ReadSms.o ReadSTL.o ReadTetGen.o ReadVtk.o SMF_State.o Tqdcfr.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteSmf.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o  .libs/libmoabio.lax/libmhdf.a/adjacency.o .libs/libmoabio.lax/libmhdf.a/file.o .libs/libmoabio.lax/libmhdf.a/sets.o .libs/libmoabio.lax/libmhdf.a/tags.o .libs/libmoabio.lax/libmhdf.a/nodes.o .libs/libmoabio.lax/libmhdf.a/util.o .libs/libmoabio.lax/libmhdf.a/status.o .libs/libmoabio.lax/libmhdf.a/connectivity.o .libs/libmoabio.lax/libmhdf.a/file-desc.o .libs/libmoabio.lax/libmhdf.a/file-handle.o
ranlib .libs/libmoabio.a
ranlib: .libs/libmoabio.a: Disk quota exceeded
sincerely,
 -The Fathomatic
