[MOAB-dev] r3864 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu
Fri May 7 15:42:11 CDT 2010
Author: kraftche
Date: 2010-05-07 15:42:11 -0500 (Fri, 07 May 2010)
New Revision: 3864
Modified:
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
fix some debug output
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-07 20:41:52 UTC (rev 3863)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp 2010-05-07 20:42:11 UTC (rev 3864)
@@ -1805,7 +1805,7 @@
//char buffer[256];
//sprintf(buffer, "write_shared_set_descriptions( %u )", (unsigned)parallelSets.size() );
//tprint( buffer );
-tprint( "write_shared_set_descriptions" );
+tprint( "write_shared_set_descriptions\n" );
const id_t start_id = setSet.first_id;
ErrorCode rval;
@@ -1838,7 +1838,7 @@
CHECK_HDF(status);
-tprint( "finished write_shared_set_descriptions" );
+tprint( "finished write_shared_set_descriptions\n" );
return MB_SUCCESS;
@@ -1847,7 +1847,7 @@
ErrorCode WriteHDF5Parallel::write_shared_set_contents( hid_t table,
IODebugTrack* dbg_track )
-tprint( "write_shared_set_contents" );
+tprint( "write_shared_set_contents\n" );
ErrorCode rval;
mhdf_Status status;
@@ -1879,7 +1879,7 @@
-tprint( "finished write_shared_set_contents" );
+tprint( "finished write_shared_set_contents\n" );
return MB_SUCCESS;
@@ -1887,7 +1887,7 @@
ErrorCode WriteHDF5Parallel::write_shared_set_children( hid_t table,
-tprint( "write_shared_set_children" );
+tprint( "write_shared_set_children\n" );
ErrorCode rval;
mhdf_Status status;
@@ -1919,7 +1919,7 @@
