[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Sun May 9 00:03:18 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/144
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
(cd .libs/libMOAB.lax/libmoabio.a && ar x /nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/src/io/.libs/libmoabio.a)
ar cru .libs/libMOAB.a  AEntityFactory.o BitTagServer.o BSPTreePoly.o DebugOutput.o DualTool.o EntitySequence.o FileOptions.o GeomTopoTool.o HigherOrderFactory.o HomXform.o AdaptiveKDTree.o AffineXform.o AxisBox.o BSPTree.o CN.o CartVect.o Matrix3.o Core.o Factory.o GeomUtil.o MeshSet.o OrientedBox.o OrientedBoxTreeTool.o Range.o RangeSeqIntersectIter.o ReadUtil.o ReaderWriterSet.o Skinner.o SysUtil.o Util.o WriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o SweptElementData.o SweptElementSeq.o SweptVertexData.o TagInfo.o TagServer.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o  .libs/libMOAB.lax/libmoabio.a/IODebugTrack.o .libs/libMOAB.lax/libmoabio.a/ReadNASTRAN.o .libs/libMOAB.lax/libmoabio.a/file.o .libs/libMOAB.lax/libmoabio.a/SMF_State.o .libs/libMOAB.lax/libmoabio.a/FileTokenizer.o .libs/libMOAB.lax/libmoab
 io.a/WriteSLAC.o .libs/libMOAB.lax/libmoabio.a/WriteGmsh.o .libs/libMOAB.lax/libmoabio.a/ReadTetGen.o .libs/libMOAB.lax/libmoabio.a/WriteGMV.o .libs/libMOAB.lax/libmoabio.a/WriteAns.o .libs/libMOAB.lax/libmoabio.a/ReadGmsh.o .libs/libMOAB.lax/libmoabio.a/tags.o .libs/libMOAB.lax/libmoabio.a/GmshUtil.o .libs/libMOAB.lax/libmoabio.a/ReadVtk.o .libs/libMOAB.lax/libmoabio.a/ReadMCNP5.o .libs/libMOAB.lax/libmoabio.a/sets.o .libs/libMOAB.lax/libmoabio.a/ExoIIUtil.o .libs/libMOAB.lax/libmoabio.a/adjacency.o .libs/libMOAB.lax/libmoabio.a/ReadIDEAS.o .libs/libMOAB.lax/libmoabio.a/WriteSmf.o .libs/libMOAB.lax/libmoabio.a/WriteSTL.o .libs/libMOAB.lax/libmoabio.a/VtkUtil.o .libs/libMOAB.lax/libmoabio.a/util.o .libs/libMOAB.lax/libmoabio.a/ReadNCDF.o .libs/libMOAB.lax/libmoabio.a/status.o .libs/libMOAB.lax/libmoabio.a/WriteTemplate.o .libs/libMOAB.lax/libmoabio.a/file-desc.o .libs/libMOAB.lax/libmoabio.a/ReadHDF5.o .libs/libMOAB.lax/libmoabio.a/nodes.o .libs/libMOAB.lax/libmoabio.a/ReadA
 BAQUS.o .libs/libMOAB.lax/libmoabio.a/WriteVtk.o .libs/libMOAB.lax/libmoabio.a/connectivity.o .libs/libMOAB.lax/libmoabio.a/WriteHDF5.o .libs/libMOAB.lax/libmoabio.a/ReadSms.o .libs/libMOAB.lax/libmoabio.a/WriteNCDF.o .libs/libMOAB.lax/libmoabio.a/file-handle.o .libs/libMOAB.lax/libmoabio.a/ReadSmf.o .libs/libMOAB.lax/libmoabio.a/ReadSTL.o .libs/libMOAB.lax/libmoabio.a/Tqdcfr.o
ranlib .libs/libMOAB.a
rm -fr .libs/libMOAB.lax
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
Making all in oldinc
make[6]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/src/oldinc'
make[6]: Nothing to be done for `all'.
Making all in test
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test'
Making all in .
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test'
make[5]: Nothing to be done for `all-am'.
Making all in io
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/io'
make[5]: Nothing to be done for `all'.
Making all in dual
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/dual'
Making all in obb
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/obb'
Making all in perf
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/perf'
c++ -DHAVE_CONFIG_H -I. -I../../../test/perf -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../../src/io/mhdf/include -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT point_in_elem.o -MD -MP -MF .deps/point_in_elem.Tpo -c -o point_in_elem.o ../../../test/perf/point_in_elem.cpp
mv -f .deps/point_in_elem.Tpo .deps/point_in_elem.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -O2 -DNDEBUG   -o point_in_elem point_in_elem.o ../../src/libMOAB.la -lm
mkdir .libs
c++ -Wall -pipe -O2 -DNDEBUG -o point_in_elem point_in_elem.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
Making all in h5file
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/h5file'
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/test/oldinc'
Making all in itaps
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/itaps'
Making all in imesh
make[5]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/itaps/imesh'
make  all-am
make[6]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-distcheck/build/moab-3.99/_build/itaps/imesh'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -I. -I../../../itaps/imesh -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=../../../itaps/imesh -I../../../itaps/imesh/.. -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c -o iMesh_MOAB.lo ../../../itaps/imesh/iMesh_MOAB.cpp
../../libtool: line 1283: iMesh_MOAB.loT: Disk quota exceeded
../../libtool: line 1372: iMesh_MOAB.loT: Disk quota exceeded
 c++ -DHAVE_CONFIG_H -I. -I../../../itaps/imesh -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=../../../itaps/imesh -I../../../itaps/imesh/.. -I../../../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c ../../../itaps/imesh/iMesh_MOAB.cpp -o iMesh_MOAB.o
Assembler messages:
Fatal error: can't create iMesh_MOAB.o: Disk quota exceeded
../../../itaps/imesh/iMesh_MOAB.cpp:2777: fatal error: error writing to -: Broken pipe
compilation terminated.
sincerely,
 -The Fathomatic
