[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Tue Apr 13 00:16:19 CDT 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/118
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
Running test_hex9 ...
Running test_hex20 ...
Running test_hex27 ...
Running test_read_tri6_side ...
Running test_read_shell_side ...
Running test_read_shell_edge ...
Running test_read_hex20_side ...
Running test_read_block_ids ...
Running test_read_sideset_ids ...
Running test_read_nodeset_ids ...
PASS: exodus_test
Running test_read_nodes ...
Running test_read_quads ...
Running test_read_material_set ...
Running test_read_geom_set ...
PASS: gmsh_test
Running test_read_tets ...
Running test_read_prisms ...
Running test_read_hexes ...
Running test_read_material_set1 ...
Running test_read_material_set2 ...
PASS: nastran_test
Running test_read_ascii ...
Running test_write_ascii ...
Running test_type_option ...
Running test_detect_type ...
Running test_endian_option ...
Running test_big_endian ...
Running test_little_endian ...
Running test_detect_byte_order ...
PASS: stl_test
MBErrorCode Test Failed: MB_SUCCESS == rval
  at line 37 of '../../../test/io/smf_test.cc'
  Expected value: Success (0)
  Actual value:   File Not Found (7)
  test_read_nodes: FAILED
Running test_read_triangles ...
  test_read_triangles: FAILED
FAIL: smf_test
1 of 8 tests failed
sincerely,
 -The Fathomatic
