[MOAB-dev] r3763 - in MOAB/trunk/src: . io moab parallel
tautges at mcs.anl.gov
Fri Apr 9 20:57:57 CDT 2010
Author: tautges
Date: 2010-04-09 20:57:56 -0500 (Fri, 09 Apr 2010)
New Revision: 3763
Modified:
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/io/Tqdcfr.cpp
MOAB/trunk/src/io/Tqdcfr.hpp
MOAB/trunk/src/moab/GeomTopoTool.hpp
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
Fix several bugs, most importantly conversion of edges to higher-order edges in
.cub reader. mbparallelcomm_test now works for 64brick mesh with higher-order nodes,
and for tjunc7 with up to 20 procs.
Core.cpp: fixed a bit of formatting
GeomTopoTool.hpp: changed order of initialization to get rid of warnings
ParallelComm.cpp:
- inserting more debug output, and another round of shared handle checking
after shared verts are found but before shared ents are found
- resize some vectors again in case buffProcs.size() has changed
- in a few places, changed calls to get_connectivity to get all verts, not
just corner ones
Tqdcfr.cpp:
- store hasMidNodes in BlockHeader, instead of recomputing that data later
- check for higher-order nodes on bounding edges as well as faces
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp 2010-04-09 13:50:26 UTC (rev 3762)
+++ MOAB/trunk/src/Core.cpp 2010-04-10 01:57:56 UTC (rev 3763)
@@ -2335,8 +2335,8 @@
ErrorCode Core::convert_entities( const EntityHandle meshset,
- const bool mid_side, const bool mid_face, const bool mid_volume,
- Interface::HONodeAddedRemoved* function_object )
+ const bool mid_side, const bool mid_face, const bool mid_volume,
+ Interface::HONodeAddedRemoved* function_object )
HigherOrderFactory fact(this, function_object);
return fact.convert(meshset, mid_side, mid_face, mid_volume);
Modified: MOAB/trunk/src/io/Tqdcfr.cpp
--- MOAB/trunk/src/io/Tqdcfr.cpp 2010-04-09 13:50:26 UTC (rev 3762)
+++ MOAB/trunk/src/io/Tqdcfr.cpp 2010-04-10 01:57:56 UTC (rev 3763)
@@ -329,6 +329,7 @@
// read blocks...
if (debug) std::cout << "Reading blocks... ";
+ Range ho_entities;
for (unsigned int blindex = 0;
blindex < mesh_model->feModelHeader.blockArray.numEntities;
blindex++) {
@@ -337,6 +338,8 @@
if (MB_SUCCESS != result)
return result;
if (debug) std::cout << mesh_model->feModelHeader.blockArray.numEntities
<< " read successfully." << std::endl;;
@@ -739,8 +742,8 @@
ErrorCode Tqdcfr::read_block(const double data_version,
- Tqdcfr::ModelEntry *model,
- Tqdcfr::BlockHeader *blockh)
+ Tqdcfr::ModelEntry *model,
+ Tqdcfr::BlockHeader *blockh)
if (blockh->memCt == 0) return MB_SUCCESS;
@@ -798,13 +801,21 @@
// contains an entity set, but we still need to call it on any elements
// directly in the block (rather than a geometry subset). So bypass
