[MOAB-dev] Errors reading more than 1 mesh file
    Robert Smith
    smithrm at mcs.anl.gov
    Fri Apr  9 12:49:08 CDT 2010
I have been having problems testing the Coupler.  It asserts in
ParallelComm::pack_shared_handles() because the sharedEnts Range from
the ParallelComm object does not equal the all_shared Range
constructed in the function.  This Range is constructed by getting all
entities in the Core via get_entities_by _handle(0, all_shared).  Then
those entities with PSTATUS tag not set (i.e. not shared) are
subtracted from the Range.
This all looks reasonable and works no matter how many meshes you read
in as long as you have the same ParallelComm and Core objects for each
mesh load.
But in the coupler test it reads 2 mesh files using 1 Core object and
2 different ParallelComm and ReadParallel pairs of objects as follows:
   for (unsigned int i = 0; i < filenames.size(); i++) {
     pcs[i] = new ParallelComm(mbImpl);
     rps[i] = new ReadParallel(mbImpl, pcs[i]);
     result = rps[i]->load_file(filenames[i], 0,
FileOptions(opts.c_str()));
     PRINT_LAST_ERROR;
In this scenario, the second ReadParallel::load_file() call fails when
doing PARALLEL_RESOLVE_SHARED_ENTS.   It calls pack_shared_handles()
during that operation.  The value of all_shared will have ALL entities
from BOTH meshes, whereas the sharedEnts range from the ParallelComm
object and will only have the shared entities for the mesh just read.
My conclusion is either
A - You should not read in multiple meshes in the manner described
above.
or
B - ParallelComm::pack_shared_handles() should either construct
all_shared differently to only look at the shared entities associated
with the mesh(es) read by this ParallelComm or the assertion just
isn't valid and should be removed.
I've tried removing the assertion and the Coupler seems to work (I'm
trying to interpret the results).
However I'd like some feedback on this analysis and whether this is
the fix or is there some deeper problem.
--Bob
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100409/fbe3d635/attachment.htm>
