[MOAB-dev] r3764 - MOAB/trunk/tools/mbzoltan
tautges at mcs.anl.gov
Fri Apr 9 21:44:20 CDT 2010
Author: tautges
Date: 2010-04-09 21:44:20 -0500 (Fri, 09 Apr 2010)
New Revision: 3764
Modified:
MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
Log:
Adding warning for when empty partition sets are generated.
Un-extruded tjunction mesh now reads properly on 64 procs on laptop.
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2010-04-10 01:57:56 UTC (rev 3763)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.cpp 2010-04-10 02:44:20 UTC (rev 3764)
@@ -481,6 +481,20 @@
for (rit = elems.begin(), i = 0; rit != elems.end(); rit++, i++) {
result = mbImpl->add_entities(part_sets[assignment[i]], &(*rit), 1); RR;
+ // check for empty sets, warn if there are any
+ std::vector<unsigned int> empty_sets;
+ for (i = 0; i < nparts; i++) {
+ int num_ents = 0;
+ result = mbImpl->get_number_entities_by_handle(part_sets[i], num_ents);
+ if (MB_SUCCESS != result || !num_ents) empty_sets.push_back(i);
+ if (!empty_sets.empty()) {
+ std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: ";
+ for (std::vector<unsigned int>::iterator vit = empty_sets.begin(); vit != empty_sets.end(); vit++)
+ std::cout << *vit << " ";
+ std::cout << std::endl;
if (write_as_tags) {
@@ -576,7 +590,7 @@
int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
int *adjs, int *length)
- int i;
+ unsigned int i;
int j;
int *numPts, *nborProcs;
int sum, ptsPerProc, ptsAssigned, mySize;
@@ -595,7 +609,7 @@
ptsPerProc = npts / mbpc->proc_config().proc_size();
ptsAssigned = 0;
- for (i=0; (int) i < mbpc->proc_config().proc_size()-1; i++)
+ for (i=0; i < mbpc->proc_config().proc_size()-1; i++)
numPts[i] = ptsPerProc;
ptsAssigned += ptsPerProc;
@@ -627,7 +641,7 @@
sendProcs = nborProcs + (sendNborId - adjs);
- for (i=1; (int)i<mbpc->proc_config().proc_size(); i++)
+ for (i=1; i<mbpc->proc_config().proc_size(); i++)
MPI_Send(&numPts[i], 1, MPI_INT, i, 0x00,MPI_COMM_WORLD);
