[MOAB-dev] r3721 - MOAB/trunk/src
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Mar 29 08:15:52 CDT 2010
Author: kraftche
Date: 2010-03-29 08:15:51 -0500 (Mon, 29 Mar 2010)
New Revision: 3721
Modified:
   MOAB/trunk/src/Core.cpp
Log:
Correctly handle root set in:
  type_from_handle
  dimension_from_handle
  get_meshset_options
  contains_entities
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2010-03-29 13:14:05 UTC (rev 3720)
+++ MOAB/trunk/src/Core.cpp	2010-03-29 13:15:51 UTC (rev 3721)
@@ -313,7 +313,10 @@
 //! get the type from a handle, returns type
 EntityType Core::type_from_handle(const EntityHandle handle) const
-  return TYPE_FROM_HANDLE(handle);
+  if (!handle) // root set
+    return MBENTITYSET;
+  else
+    return TYPE_FROM_HANDLE(handle);
 //! get the id from a handle, returns id
@@ -338,7 +341,10 @@
 int Core::dimension_from_handle(const EntityHandle handle) const
-  return CN::Dimension(TYPE_FROM_HANDLE(handle));
+    return 4;
+  else
+    return CN::Dimension(TYPE_FROM_HANDLE(handle));
 //! load mesh from data in file
@@ -2564,6 +2570,11 @@
 ErrorCode Core::get_meshset_options( const EntityHandle ms_handle,
                                           unsigned int& options) const
+  if (!ms_handle) { // root set
+    options = MESHSET_SET;
+    return MB_SUCCESS;
   const MeshSet* set = get_mesh_set( sequence_manager(), ms_handle );
   if (!set)
     return MB_ENTITY_NOT_FOUND;
@@ -2694,8 +2705,9 @@
                                int num_entities,
                                const int operation_type)
-  MeshSet* set = get_mesh_set( sequence_manager(), meshset );
-  if (set)
+  if (!meshset) // root
+    return true;
+  else if (MeshSet* set = get_mesh_set( sequence_manager(), meshset ))
     return set->contains_entities(entities, num_entities, operation_type);
   else
     return false;
