[MOAB-dev] r3720 - MOAB/trunk/src
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Mar 29 08:14:06 CDT 2010
Author: kraftche
Date: 2010-03-29 08:14:05 -0500 (Mon, 29 Mar 2010)
New Revision: 3720
Modified:
   MOAB/trunk/src/Core.cpp
Log:
use switch statement rather than array indexing to convert moab::ErrorCode to string because a) performance should never be an issue for this function and b) it is safer
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2010-03-29 13:11:11 UTC (rev 3719)
+++ MOAB/trunk/src/Core.cpp	2010-03-29 13:14:05 UTC (rev 3720)
@@ -2969,28 +2969,28 @@
   return mError->get_last_error(info);
+#define MB_CASE_STRING(A) case A: return #A;
 std::string Core::get_error_string(const ErrorCode code) const
-  static const char* errorStrings[MB_FAILURE+1] = {
-    "MB_SUCCESS",
-    "MB_INDEX_OUT_OF_RANGE",
-    "MB_TYPE_OUT_OF_RANGE",
-    "MB_MEMORY_ALLOCATION_FAILED",
-    "MB_ENTITY_NOT_FOUND",
-    "MB_MULTIPLE_ENTITIES_FOUND",
-    "MB_TAG_NOT_FOUND",
-    "MB_FILE_DOES_NOT_EXIST",
-    "MB_FILE_WRITE_ERROR",
-    "MB_NOT_IMPLEMENTED",
-    "MB_ALREADY_ALLOCATED",
-    "MB_VARIABLE_DATA_LENGTH",
-    "MB_INVALID_SIZE",
-    "MB_UNSUPPORTED_OPERATION",
-    "MB_UNHANDLED_OPTION",
-    "MB_FAILURE",
-  return errorStrings[code];
+  switch (code) {
+    MB_CASE_STRING(MB_SUCCESS);
+    MB_CASE_STRING(MB_INDEX_OUT_OF_RANGE);
+    MB_CASE_STRING(MB_TYPE_OUT_OF_RANGE);
+    MB_CASE_STRING(MB_MEMORY_ALLOCATION_FAILED);
+    MB_CASE_STRING(MB_ENTITY_NOT_FOUND);
+    MB_CASE_STRING(MB_MULTIPLE_ENTITIES_FOUND);
+    MB_CASE_STRING(MB_TAG_NOT_FOUND);
+    MB_CASE_STRING(MB_FILE_DOES_NOT_EXIST);
+    MB_CASE_STRING(MB_FILE_WRITE_ERROR);
+    MB_CASE_STRING(MB_NOT_IMPLEMENTED);
+    MB_CASE_STRING(MB_ALREADY_ALLOCATED);
+    MB_CASE_STRING(MB_VARIABLE_DATA_LENGTH);
+    MB_CASE_STRING(MB_INVALID_SIZE);
+    MB_CASE_STRING(MB_UNSUPPORTED_OPERATION);
+    MB_CASE_STRING(MB_UNHANDLED_OPTION);
+    MB_CASE_STRING(MB_FAILURE);
+    default: assert(!"unknown error code"); return "(UNKNOWN ERROR CODE)";
 void Core::print(const EntityHandle ms_handle, const char *prefix,
