[MOAB-dev] r3722 - MOAB/trunk/test
kraftche at cae.wisc.edu
Mon Mar 29 08:16:14 CDT 2010
Author: kraftche
Date: 2010-03-29 08:16:14 -0500 (Mon, 29 Mar 2010)
New Revision: 3722
Modified:
MOAB/trunk/test/MBTest.cpp
Log:
add tests for root set as input to various Interface functions
Modified: MOAB/trunk/test/MBTest.cpp
--- MOAB/trunk/test/MBTest.cpp 2010-03-29 13:15:51 UTC (rev 3721)
+++ MOAB/trunk/test/MBTest.cpp 2010-03-29 13:16:14 UTC (rev 3722)
@@ -8395,8 +8395,135 @@
return MB_SUCCESS;
+/** Test behavior of various functions when passed the root set
+ErrorCode mb_root_set_test( Interface* mb )
+ ErrorCode rval;
+ EntityHandle rs = mb->get_root_set();
+ // expect root set to have zero handle
+ CHECK(!rs);
+ // check type
+ EntityType type = mb->type_from_handle( rs );
+ CHECK( MBENTITYSET == type );
+ // Check dimension.
+ // Use an existing set to determine the expected
+ // result of this function, rather than hard-coding it.
+ Range sets;
+ rval = mb->get_entities_by_type( 0, MBENTITYSET, sets );
+ CHKERR( rval );
+ CHECK(!sets.empty());
+ EntityHandle some_set = sets.front();
+ int exp_dim = mb->dimension_from_handle( some_set );
+ int dim = mb->dimension_from_handle( rs );
+ CHECK( exp_dim == dim );
+ // test some stuff that should fail
+ rval = mb->clear_meshset( &rs, 1 );
+ CHECK( MB_SUCCESS != rval );
+ rval = mb->set_meshset_options( rs, MESHSET_ORDERED );
+ rval = mb->subtract_meshset( rs, some_set );
+ rval = mb->intersect_meshset( rs, some_set );
+ rval = mb->unite_meshset( rs, some_set );
+ // add/remove should fail for root set?
+ rval = mb->add_entities( rs, &some_set, 1 );
+ rval = mb->remove_entities( rs, &some_set, 1 );
+ rval = mb->replace_entities( rs, &some_set, &some_set, 1 );
+ // check flags
+ unsigned flags;
+ rval = mb->get_meshset_options( rs, flags );
+ CHECK( flags & MESHSET_SET );
+ CHECK( !(flags & MESHSET_ORDERED) );
+ CHECK( !(flags & MESHSET_TRACK_OWNER) );
+ // contains tests
+ bool c = mb->contains_entities( rs, &some_set, 1 );
+ CHECK( c );
+ Range sets2;
+ rval = mb->get_contained_meshsets( rs, sets2 );
+ CHKERR(rval);
+ CHECK( sets == sets2 );
+ int count;
+ rval = mb->num_contained_meshsets( rs, &count );
+ CHKERR(rval);
+ CHECK( count == (int)sets.size() );
+ // Apparently, the expected behavior for
+ // parent/child queries on the root set
+ // is to successfully return nothing.
+ sets2.clear();
+ rval = mb->get_parent_meshsets( rs, sets2 );
+ CHKERR(rval);
+ CHECK(sets2.empty());
+ sets2.clear();
+ rval = mb->get_parent_meshsets( rs, sets2, 2 );
+ CHKERR(rval);
+ sets2.clear();
+ rval = mb->get_child_meshsets( rs, sets2 );
+ CHKERR(rval);
+ sets2.clear();
+ rval = mb->get_child_meshsets( rs, sets2, 2 );
+ CHKERR(rval);
+ count = 10;
+ rval = mb->num_parent_meshsets( rs, &count );
+ CHKERR(rval);
+ CHECK(!count);
+ count = 10;
+ rval = mb->num_parent_meshsets( rs, &count, 2 );
+ CHKERR(rval);
+ CHECK(!count);
+ count = 10;
+ rval = mb->num_child_meshsets( rs, &count );
+ CHKERR(rval);
+ CHECK(!count);
+ count = 10;
+ rval = mb->num_child_meshsets( rs, &count, 2 );
+ CHKERR(rval);
+ CHECK(!count);
+ rval = mb->add_parent_meshset( rs, some_set );
+ CHECK(MB_SUCCESS != rval);
+ rval = mb->add_parent_meshsets( rs, &some_set, 1 );
+ rval = mb->add_child_meshset( rs, some_set );
+ rval = mb->add_child_meshsets( rs, &some_set, 1 );
+ rval = mb->add_parent_child( rs, some_set );
+ rval = mb->remove_parent_child( rs, some_set );
+ rval = mb->remove_parent_meshset( rs, some_set );
+ rval = mb->remove_child_meshset( rs, some_set );
+ return MB_SUCCESS;
static void usage(const char* exe) {
cerr << "Usage: " << exe << " [-nostress] [-d input_file_dir]\n";
exit (1);
@@ -8511,6 +8638,7 @@
RUN_TEST( mb_enum_string_test );
RUN_TEST( mb_merge_update_test );
RUN_TEST( mb_type_is_maxtype_test );
+ RUN_TEST( mb_root_set_test );
RUN_TEST( mb_merge_test );
if (stress_test) RUN_TEST( mb_stress_test );
