[MOAB-dev] r3690 - MOAB/trunk/itaps/imesh
kraftche at cae.wisc.edu
Mon Mar 22 16:21:49 CDT 2010
Author: kraftche
Date: 2010-03-22 16:21:49 -0500 (Mon, 22 Mar 2010)
New Revision: 3690
Modified:
MOAB/trunk/itaps/imesh/iMeshP_unit_tests.cpp
Log:
fix bugs preventing iMeshP unit tests from working in serial (still fail in parallel)
Modified: MOAB/trunk/itaps/imesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/itaps/imesh/iMeshP_unit_tests.cpp 2010-03-22 21:18:27 UTC (rev 3689)
+++ MOAB/trunk/itaps/imesh/iMeshP_unit_tests.cpp 2010-03-22 21:21:49 UTC (rev 3690)
@@ -8,6 +8,7 @@
#include <math.h>
#include <map>
#include <string.h>
+#include <stdio.h> // remove()
#if !defined(_MSC_VER) && !defined(__MINGW32__)
#include <unistd.h>
@@ -779,7 +780,9 @@
// from number of parts (see create_mesh(..) function.)
const int expected_global_quad_count = 4 * num_parts;
const int num_col = 2 * (num_parts / 2 + num_parts % 2);
- const int expected_global_vtx_count = 5 + 5*num_col - 4*(num_parts % 2);
+ const int expected_global_vtx_count = num_parts == 1 ? 9 :
+ num_parts % 2 ? 1 + 5*num_col :
+ 5 + 5*num_col;
// test getNumOf*All for root set
int ierr, count;
@@ -874,6 +877,7 @@
std::vector<iBase_EntityHandle> act_quads( ptr, ptr+num_ent );
free(ptr);
junk1 = num_ent = 0;
+ ptr = 0;
iMeshP_getEntities( imesh, prtn, part, root, iBase_ALL_TYPES,
iMesh_ALL_TOPOLOGIES,
&ptr, &junk1, &num_ent, &ierr ); CHKERR;
@@ -927,6 +931,7 @@
// compare local contents (using non-root set)
junk1 = 0; num_ent = 0;
+ ptr = 0;
iMeshP_getEntities( imesh, prtn, part, set, test_type ? iBase_FACE : iBase_ALL_TYPES,
test_type ? iMesh_ALL_TOPOLOGIES : iMesh_QUADRILATERAL,
@@ -1225,7 +1230,7 @@
// test iMeshP_getPartNborsArr
iMeshP_Part* nbor_arr = 0;
- junk1 = 0, junk2 = handles.size();
+ junk1 = handles.size(), junk2 = 0;
int junk3 = 0, nbor_size;
iMeshP_getPartNborsArr( imesh, prtn, &handles[0], handles.size(), iBase_VERTEX,
&count_arr, &junk1, &junk2,
