[MOAB-dev] r3691 - MOAB/trunk/examples
    kraftche at cae.wisc.edu
    Mon Mar 22 17:28:42 CDT 2010
Author: kraftche
Date: 2010-03-22 17:28:42 -0500 (Mon, 22 Mar 2010)
New Revision: 3691
Added:
   MOAB/trunk/examples/KDTree.cpp
Modified:
   MOAB/trunk/examples/Makefile.am
Log:
add simple example that uses a KDTree to find the hex containing a point
Added: MOAB/trunk/examples/KDTree.cpp
--- MOAB/trunk/examples/KDTree.cpp	                        (rev 0)
+++ MOAB/trunk/examples/KDTree.cpp	2010-03-22 22:28:42 UTC (rev 3691)
@@ -0,0 +1,135 @@
+/* Simple example of use of moab::AdaptiveKDTree class.
+   Given a hexahedral mesh, find the hexahedron containing each
+   input position.
+#include "moab/Core.hpp"
+#include "moab/AdaptiveKDTree.hpp"
+#include "moab/Range.hpp"
+#include "moab/GeomUtil.hpp"
+#include <iostream>
+#include <string>
+const double EPSILON = 1e-6; // tolerance to use in intersection checks
+// Help with error handling.  Given ErrorCode, print
+// corresponding string and any available message.
+void print_error( moab::Interface& mb, moab::ErrorCode err )
+  std::string message;
+  std::string code;
+  if (moab::MB_SUCCESS != mb.get_last_error( message ))
+    message.clear();
+  code = mb.get_error_string(err);
+  std::cerr << "Error: " << code << std::endl;
+  if (!message.empty())
+    std::cerr << "  " << message << std::endl;
+// Print diagnostic info for unexpected failures.
+#define CHKERR(err) do { if (moab::MB_SUCCESS != (err)) { \
+  print_error( mb, (err) ); \
+  std::cerr << "Unexpected failure at: " << __FILE__ << ":" << __LINE__ << std::endl; \
+  return 2; \
+  } } while (false)
+// Given an entity set and a point, find the hex contained in the
+// entity set which in turn contains the specified point.  Returns
+// 0 if point is not in any hexahedron.
+moab::EntityHandle hex_containing_point( moab::Interface& mb,
+                                         moab::EntityHandle set,
+                                         const double point[3] );
+// Print hex containing point.
+void print_hex( moab::Interface& mb, moab::EntityHandle hex );
+int main( )
+  std::string filename;
+  std::cout << "Hex mesh file name: ";
+  std::cin >> filename;
+  moab::ErrorCode rval;
+  moab::Core moab;
+  moab::Interface& mb = moab;
+  rval = mb.load_file( filename.c_str() );
+  if (moab::MB_SUCCESS != rval) {
+    print_error(mb,rval);
+    std::cerr << filename << ": file load failed" << std::endl;
+    return 1;
+  moab::Range elems;
+  rval = mb.get_entities_by_type( 0, moab::MBHEX, elems ); CHKERR(rval);
+  if (elems.empty()) {
+    std::cerr << filename << ": file containd no hexahedra" << std::endl;
+    return 1;
+  moab::EntityHandle tree_root;
+  moab::AdaptiveKDTree tool( &mb );
+  rval = tool.build_tree( elems, tree_root ); CHKERR(rval);
+  for (;;) {
+    double point[3];
+    std::cout << "Point coordinates: ";
+    if (!(std::cin >> point[0] >> point[1] >> point[2]))
+      break;
+    moab::EntityHandle leaf;
+    rval = tool.leaf_containing_point( tree_root, point, leaf ); CHKERR(rval);
+    moab::EntityHandle hex = hex_containing_point( mb, leaf, point );
+    if (0 == hex)
+      std::cout << "Point is not contained in any hexahedron." << std::endl;
+    else
+      print_hex( mb, hex );
+  return 0;
+  moab::CartVect pt(point); // input location
+  moab::CartVect coords[8]; // coordinates of corners of hexahedron
+  const moab::EntityHandle* conn; // hex connectivity
+  int conn_len;
+  std::vector<moab::EntityHandle> hexes;
+  std::vector<moab::EntityHandle>::const_iterator i;
+  rval = mb.get_entities_by_type( set, moab::MBHEX, hexes ); CHKERR(rval);
+  for (i = hexes.begin(); i != hexes.end(); ++i) {
+    rval = mb.get_connectivity( *i, conn, conn_len ); CHKERR(rval);
+    rval = mb.get_coords( conn, 8, &coords[0][0] ); CHKERR(rval);
+    if (moab::GeomUtil::point_in_trilinear_hex( coords, pt, EPSILON ))
+      return *i;
+  return 0;
+  int id = mb.id_from_handle(hex);
+  double coords[3*8]; // coordinates of corners of hexahedron
+  int conn_len;
+  mb.get_connectivity( hex, conn, conn_len );
+  mb.get_coords( conn, 8, coords );
+  std::cout << " Point is in hex " << id << " with corners: " << std::endl;
+  for (int i = 0; i < 8; ++i) {
+    std::cout << " (" << coords[3*i]
+              << ", " << coords[3*i+1]
+              << ", " << coords[3*i+2]
+              << ")" << std::endl;
Modified: MOAB/trunk/examples/Makefile.am
--- MOAB/trunk/examples/Makefile.am	2010-03-22 21:21:49 UTC (rev 3690)
+++ MOAB/trunk/examples/Makefile.am	2010-03-22 22:28:42 UTC (rev 3691)
@@ -1,6 +1,7 @@
 check_PROGRAMS = FileRead \
                  GeomSetHierarchy \
                  GetEntities \
+                 KDTree \
                  SetsNTags \
                  SkinMesh \
                  SurfArea
@@ -16,6 +17,7 @@
 SetsNTags_SOURCES = SetsNTags.cpp
 SkinMesh_SOURCES = SkinMesh.cpp
 SurfArea_SOURCES = SurfArea.cpp
+KDTree_SOURCES = KDTree.cpp
 exampledir = ${docdir}/examples
 nobase_example_DATA = \
@@ -24,6 +26,7 @@
                GeomSetHierarchy.cpp \
                simple/GetEntities.cpp \
                simple/makefile \
+               KDTree.cpp \
                SetsNTags.cpp \
                SkinMesh.cpp \
                SurfArea.cpp
