[MOAB-dev] r3689 - in MOAB/trunk/src/parallel: . moab
    kraftche at cae.wisc.edu
    Mon Mar 22 16:18:27 CDT 2010
Author: kraftche
Date: 2010-03-22 16:18:27 -0500 (Mon, 22 Mar 2010)
New Revision: 3689
Modified:
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
o Make containers passed by reference to ParallelComm::exchange_tags
  const because ParallelComm shouldn't be modifying them.
o In ParallelComm::exchange_tags, if source tag is different than
  destination tag, also copy values locally on owned entities.
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2010-03-22 20:40:35 UTC (rev 3688)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2010-03-22 21:18:27 UTC (rev 3689)
@@ -4783,9 +4783,9 @@
-ErrorCode ParallelComm::exchange_tags(std::vector<Tag> &src_tags,
-                                          std::vector<Tag> &dst_tags,
-                                          Range &entities)
+ErrorCode ParallelComm::exchange_tags( const std::vector<Tag> &src_tags,
+                                       const std::vector<Tag> &dst_tags,
+                                       const Range &entities_in)
   ErrorCode result;
   int success;
@@ -4829,7 +4829,7 @@
   sendReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
     // take all shared entities if incoming list is empty
-  if (entities.empty()) entities = sharedEnts;
+  const Range& entities = entities_in.empty() ? sharedEnts : entities_in;
   int dum_ack_buff;
@@ -4849,7 +4849,7 @@
       // pack-send; this also posts receives if store_remote_handles is true
     std::vector<Range> tag_ranges;
-    for (std::vector<Tag>::iterator vit = src_tags.begin(); vit != src_tags.end(); vit++) {
+    for (std::vector<Tag>::const_iterator vit = src_tags.begin(); vit != src_tags.end(); vit++) {
       const void* ptr;
       int size;
       if (tagServer->get_default_data_ref( *vit, ptr, size ) != MB_SUCCESS) {
@@ -4924,6 +4924,42 @@
     RRA("Failure in waitall in tag exchange.");
+    // If source tag is not equal to destination tag, then
+    // do local copy for owned entities (communicate w/ self)
+  assert(src_tags.size() == dst_tags.size());
+  if (src_tags != dst_tags) {
+    std::vector<unsigned char> data;
+    Range owned_ents(entities_in);
+    result = filter_pstatus(owned_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
+    RRA("Failure to get subset of owned entities");
+    for (size_t i = 0; i < src_tags.size(); ++i) {
+      if (src_tags[i] == dst_tags[i])
+        continue;
+      Range tagged_ents(owned_ents);
+      result = mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE,
+                        &src_tags[0], 0, 1, tagged_ents, Interface::INTERSECT );
+      RRA("get_entities_by_type_and_tag(type == MBMAXTYPE) failed.");
+      int size, size2;
+      result = mbImpl->tag_get_size( src_tags[i], size );
+      RRA("tag_get_size failed.");
+      result = mbImpl->tag_get_size( dst_tags[i], size2 );
+      if (size != size2) {
+        result = MB_FAILURE;
+        RRA("tag sizes don't match")
+      data.resize( size * tagged_ents.size() );
+      result = mbImpl->tag_get_data( src_tags[i], tagged_ents, &data[0] );
+      RRA("tag_get_data failed.");
+      result = mbImpl->tag_set_data( dst_tags[i], tagged_ents, &data[0] );
+      RRA("tag_set_data failed.");
 #ifdef DEBUG_COMM
   std::cerr << "Exiting exchange_tags" << std::endl; std::cerr.flush();
 #endif
Modified: MOAB/trunk/src/parallel/moab/ParallelComm.hpp
--- MOAB/trunk/src/parallel/moab/ParallelComm.hpp	2010-03-22 20:40:35 UTC (rev 3688)
+++ MOAB/trunk/src/parallel/moab/ParallelComm.hpp	2010-03-22 21:18:27 UTC (rev 3689)
@@ -190,23 +190,23 @@
      * tag (or the tag should have a default value).
      * \param tags Vector of tag handles to be exchanged
-  ErrorCode exchange_tags(std::vector<Tag> &src_tags,
-                            Range &entities);
+  ErrorCode exchange_tags( const std::vector<Tag> &src_tags,
+                           const Range &entities);
     /** \brief Exchange tags for all shared and ghosted entities
      * This function should be called collectively over the communicator for this ParallelComm
      * \param tag_name Name of tag to be exchanged
-  ErrorCode exchange_tags(const char *tag_name,
-                            Range &entities);
+  ErrorCode exchange_tags( const char *tag_name,
      * \param tagh Handle of tag to be exchanged
-  ErrorCode exchange_tags(Tag tagh,
-                            Range &entities);
+  ErrorCode exchange_tags( Tag tagh,
     /** \brief Broadcast all entities resident on from_proc to other processors
      * This function assumes remote handles are *not* being stored, since (usually)
@@ -1168,8 +1168,8 @@
   return MB_SUCCESS;
-inline ErrorCode ParallelComm::exchange_tags(const char *tag_name,
-                                                 Range &entities)
+inline ErrorCode ParallelComm::exchange_tags( const char *tag_name,
     // get the tag handle
   std::vector<Tag> tags(1);
@@ -1180,8 +1180,8 @@
   return exchange_tags(tags, tags, entities);
-inline ErrorCode ParallelComm::exchange_tags(Tag tagh,
-                                                 Range &entities)
+inline ErrorCode ParallelComm::exchange_tags( Tag tagh,
   std::vector<Tag> tags;
