[MOAB-dev] MOAB examples
James Porter
jvporter at wisc.edu
Wed Mar 17 15:15:28 CDT 2010
Why not have Makefile.GetEntities et al and then a general Makefile that
calls those? That way people can see the simple Makefiles (and call them
directly with make -f) or they could say "make GetEntities".
- Jim
On Wed, 2010-03-17 at 14:54 -0500, Timothy J. Tautges wrote:
> I'd like the 3 simple examples (GetEntities, SetsNTags, GetGeomHierarchy, or something like those names) to keep their own Makefile's and subdirs, since they're meant to be the simple read-this-first sort of examples. The others can go into the same makefile if they're small. I wonder if we should have a subdirectory there for 1-file examples, so those aren't all put up in the main examples directory?
> - tim
> From: "Robert Smith" <smithrm at mcs.anl.gov>
> To: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
> Cc: moab-dev at mcs.anl.gov
> Sent: Wednesday, March 17, 2010 6:27:35 PM GMT +00:00 Monrovia
> Subject: Re: [MOAB-dev] MOAB examples
> Your proposal does seem cleaner. Especially since they are each 1
> file and the makefiles are almost all alike.
> Also we need to put in some example mesh files to the directory. I
> was going to write a README file for the examples once they were done
> to indicate what each one does and how to invoke it.
> Does anyone have some good input mesh files to use for the examples?
> --Bob
> On Mar 17, 2010, at 1:05 PM, Jason Kraftcheck wrote:
> > Why do we have subdirectories under examples/ when all of our
> > examples (by
> > design) are a single file? Is it just so that each can have its own
> > Makefile? Would anyone mind if I were to move all the example
> > source files
> > to the top examples/ directory and remove the individual subdirs?
> > Would it
> > be a problem if all of them were to share a single Makefile? This
> > would
> > result in a simpler build system with fewer files to maintain.
> > - jason
