[MOAB-dev] MOAB examples
Timothy J. Tautges tautges at mcs.anl.gov
Wed Mar 17 14:54:32 CDT 2010
I'd like the 3 simple examples (GetEntities, SetsNTags, GetGeomHierarchy, or something like those names) to keep their own Makefile's and subdirs, since they're meant to be the simple read-this-first sort of examples.  The others can go into the same makefile if they're small.  I wonder if we should have a subdirectory there for 1-file examples, so those aren't all put up in the main examples directory?
- tim
----- Original Message -----
To: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
Cc: moab-dev at mcs.anl.gov
Sent: Wednesday, March 17, 2010 6:27:35 PM GMT +00:00 Monrovia
Subject: Re: [MOAB-dev] MOAB examples
Your proposal does seem cleaner.  Especially since they are each 1
file and the makefiles are almost all alike.
Also we need to put in some example mesh files to the directory.  I
was going to write a README file for the examples once they were done
to indicate what each one does and how to invoke it.
Does anyone have some good input mesh files to use for the examples?
--Bob
On Mar 17, 2010, at 1:05 PM, Jason Kraftcheck wrote:
> Why do we have subdirectories under examples/ when all of our
> examples (by
> design) are a single file?  Is it just so that each can have its own
> Makefile?  Would anyone mind if I were to move all the example
> source files
> to the top examples/ directory and remove the individual subdirs?
> Would it
> be a problem if all of them were to share a single Makefile?  This
> would
> result in a simpler build system with fewer files to maintain.
> - jason
