[MOAB-dev] MOAB examples
Tim Tautges
tautges at mcs.anl.gov
Wed Mar 17 16:39:20 CDT 2010
I know this seems really goofy, but I'd like to make it dead simple to see exactly how to build MOAB into applications
using a completely trivial Makefile. I'm ok with it being just for one example; the others can go into a combined
Makefile. Eventually, it may make sense to also have an example showing how to incorporate MOAB into an app's
autoconf-libtool-based build and, it pains me to say this, cmake-based build.
- tim
James Porter wrote:
> Why not have Makefile.GetEntities et al and then a general Makefile that
> calls those? That way people can see the simple Makefiles (and call them
> directly with make -f) or they could say "make GetEntities".
> - Jim
> On Wed, 2010-03-17 at 14:54 -0500, Timothy J. Tautges wrote:
>> I'd like the 3 simple examples (GetEntities, SetsNTags, GetGeomHierarchy, or something like those names) to keep their own Makefile's and subdirs, since they're meant to be the simple read-this-first sort of examples. The others can go into the same makefile if they're small. I wonder if we should have a subdirectory there for 1-file examples, so those aren't all put up in the main examples directory?
>> - tim
>> ----- Original Message -----
>> From: "Robert Smith" <smithrm at mcs.anl.gov>
>> To: "Jason Kraftcheck" <kraftche at cae.wisc.edu>
>> Cc: moab-dev at mcs.anl.gov
>> Sent: Wednesday, March 17, 2010 6:27:35 PM GMT +00:00 Monrovia
>> Subject: Re: [MOAB-dev] MOAB examples
>> Your proposal does seem cleaner. Especially since they are each 1
>> file and the makefiles are almost all alike.
>> Also we need to put in some example mesh files to the directory. I
>> was going to write a README file for the examples once they were done
>> to indicate what each one does and how to invoke it.
>> Does anyone have some good input mesh files to use for the examples?
>> --Bob
>> On Mar 17, 2010, at 1:05 PM, Jason Kraftcheck wrote:
>>> Why do we have subdirectories under examples/ when all of our
>>> examples (by
>>> design) are a single file? Is it just so that each can have its own
>>> Makefile? Would anyone mind if I were to move all the example
>>> source files
>>> to the top examples/ directory and remove the individual subdirs?
>>> Would it
>>> be a problem if all of them were to share a single Makefile? This
>>> would
>>> result in a simpler build system with fewer files to maintain.
>>> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
