[MOAB-dev] dagmc's ray_fire_test utility
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Feb  8 19:49:18 CST 2010
Fine with me.
- tim
Steve Jackson wrote:
> I'm going to be doing some work with the ray_fire_test.cc utility located within MOAB under tools/dagmc.  I'd like to change the command-line interface of this testing utility.  (Specifically, I plan to give sensible defaults to the input parameters, so that not every call to the program needs to have 5 arguments.)  If anyone would be inconvenienced by a such a change, please let me know.
> ~S
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
