[MOAB-dev] r3536 - MOAB/trunk/tools/dagmc
    sjackson at cae.wisc.edu
    Wed Feb 10 14:28:29 CST 2010
Author: sjackson
Date: 2010-02-10 14:28:28 -0600 (Wed, 10 Feb 2010)
New Revision: 3536
Modified:
   MOAB/trunk/tools/dagmc/ray_fire_test.cc
Log:
Overhaul DagMC's ray_fire_test utility.
* Give most parameters an optional command-line
  flag and a sane default value
* Allow multiple user-specified rays (using the -f
  flag; formerly, this was the -s flag)
* Friendlier help messages and cleaner program output
* Clean up code internals
Modified: MOAB/trunk/tools/dagmc/ray_fire_test.cc
--- MOAB/trunk/tools/dagmc/ray_fire_test.cc	2010-02-09 22:20:33 UTC (rev 3535)
+++ MOAB/trunk/tools/dagmc/ray_fire_test.cc	2010-02-10 20:28:28 UTC (rev 3536)
@@ -2,6 +2,7 @@
 #include "MBCore.hpp"
 #include "DagMC.hpp"
 #include "MBTagConventions.hpp"
+#include "MBCartVect.hpp"
 #include <vector>
 #include <iostream>
@@ -23,16 +24,15 @@
 #endif
 #endif
-#define CHKERR if (MB_SUCCESS != rval) return rval
+// define following macro for verbose debugging of random ray generation
 //#define DEBUG
 void get_time_mem(double &tot_time, double &user_time,
                   double &sys_time, double &tot_mem);
-const double PI = acos(-1.0);
-double denom = 1.0 / ((double) RAND_MAX);
-double denomPI = PI * denom;
+static const double PI = acos(-1.0);
+static const double denom = 1.0 / ((double) RAND_MAX);
+static const double denomPI = PI * denom;
 inline void RNDVEC(double &u, double &v, double &w, double &az)
@@ -44,144 +44,240 @@
   w = cos(phi);
-int main( int argc, char* argv[] )
+/* program global data, including settings with their defaults*/
+typedef struct{ MBCartVect p; MBCartVect v; } ray_t;
+std::vector< ray_t > rays; // list of user-specified rays (given with -f flag)
+static double facet_tol = 1e-4;
+static double source_rad = 0;
+static int vol_index = 1;
+static int num_random_rays = 1000;
+static int randseed = 12345;
+static bool do_stat_report = false;
+static bool do_trv_stats   = false;
+static double location_az = 2.0 * PI;
+static double direction_az = location_az;
+/* Most of the argument handling code was stolen/adapted from MOAB/test/obb/obb_test.cpp */
+static void usage( const char* error, const char* opt, const char* name = "ray_fire_test" )
-  MBErrorCode rval;
+  const char* default_message = "Invalid option";
+  if (opt && !error)
+    error = default_message;
-  if (argc < 6) {
-    std::cerr << "Usage: " << argv[0] << " [-f] <filename> "
-              << " <facet_tol> <source_rad> <vol_index> <#calls> [<location_az>] [<direction_az>]" << std::endl;
-    std::cerr << "-f: report full tree statistics" << std::endl;
-    std::cerr << "-s: perform a simple ray_fire with <filename> <facet_tol> <vol_id> <x y z> <u v w>" << std::endl;
-    std::cerr << "filename: mesh or geometry filename" << std::endl;
-    std::cerr << "facet_tol: facet tolerance" << std::endl;
-    std::cerr << "source_rad: if < 0, ray at source_rad and random angle pointed at origin;" << std::endl;
-    std::cerr << "            otherwise, ray at radius and random angle, pointed in random direction;" << std::endl;
-    std::cerr << "vol_index: index of the volume at which to fire rays" << std::endl;
-    std::cerr << "#calls: # iterations of ray-tracing loop" << std::endl;
-    std::cerr << "location_az: if present, ray location is limited to between +-<azimuthal_limit> degrees" << std::endl;
-    std::cerr << "direction_az: if present, ray direction is limited to between +-<azimuthal_limit> degrees" << std::endl;
-    return 1;
+  std::ostream& str = error ? std::cerr : std::cout;
+  if (error) {
+    str << error;
+    if (opt)
+      str << ": " << opt;
+    str << std::endl;
-  // declare variables used for all ray_fires
-  const double PI = acos(-1.0);
-  char *filename;
-  double facet_tol;
-  double x, y, z, u, v, w, dist;
-  int ncalls;
-  MBEntityHandle surf = 0, vol = 0;
-  // Simply test 1 ray against 1 volume with no timing
-  if(!strcmp(argv[2], "-s")) {
-    if(11 > argc) {
-      std::cerr << "Need more input arguments for simple test" << std::endl;
-      return 1;
+  str << "Usage: " << name << " [options] input_file" << std::endl;
+  str << "       " << name << " -h" << std::endl;
-    int i=2;
-    filename = argv[i++];
-    facet_tol = atof(argv[i++]);
-    int vol_id = atoi(argv[i++]);
-    x = atof(argv[i++]);
-    y = atof(argv[i++]);
-    z = atof(argv[i++]);
-    u = atof(argv[i++]);
-    v = atof(argv[i++]);
-    w = atof(argv[i++]);
+  if( !error ){
+    str << "-h  print this help" << std::endl;
+    str << "-s  print OBB tree structural statistics" << std::endl;
+    str << "-S  track and print OBB tree traversal statistics (to be implemented soon)" << std::endl;
+    str << "-i <int>   specify volume to upon which to test ray intersections (default 1)" << std::endl;
+    str << "-t <real>  specify faceting tolerance (default 1e-4)" << std::endl;
+    str << "-n <int>   specify number of random rays to fire (default 1000)" << std::endl;
+    str << "-r <real>  random ray radius.  Random rays begin at this distance from the origin." << std::endl;
+    str << "           if < 0, fire rays inward through the origin" << std::endl;
+    str << "           if >= 0, fire random rays outward.  (default 0)" << std::endl;
+    str << "-f <x> <y> <z> <u> <v> <w>  Fire one given ray and report result." << std::endl;
+    str << "           (May be given multiple times.  -s implies -n 0)" << std::endl;
+    str << "-z <int>   seed the random number generator (default 12345)" << std::endl;
+    str << "-L <real>  if present, limit random ray Location to between +-<value> degrees" << std::endl;
+    str << "-D <real>  if present, limit random ray Direction to between +-<value> degrees" << std::endl;
-    DagMC& dagmc = *DagMC::instance();
-    rval = dagmc.load_file( filename, facet_tol );
-    if(MB_SUCCESS != rval) {
-      std::cerr << "Failed to load file." << std::endl;
-      return 2;
+  exit( error ? 1 : 0 );
-    rval = dagmc.init_OBBTree( );
-      std::cerr << "Failed to initialize DagMC." << std::endl;
-      return 2;
-    vol = dagmc.entity_by_id(3, vol_id);
-    if(0 == vol) {
-      std::cerr << "Problem getting volume." << std::endl;
-      return 2;
+static const char* get_option( int& i, int argc, char* argv[] ) {
+  ++i;
+  if (i == argc)
+    usage( "Expected argument following option", argv[i-1] );
+  return argv[i];
-    rval = dagmc.ray_fire( vol, 0, 1, u, v, w, x, y, z, DBL_MAX, dist, surf );
-      std::cerr << "Problem with ray_fire" << std::endl;
-      return 2;
+static int get_int_option( int& i, int argc, char* argv[] ) {
+  const char* str = get_option( i, argc, argv );
+  char* end_ptr;
+  long val = strtol( str, &end_ptr, 0 );
+  if (!*str || *end_ptr)
+    usage( "Expected integer following option", argv[i-1] );
+  return val;
-    if(0 == surf) {
-      std::cerr << "Particle is lost" << std::endl;
-      return 2;
+static double get_double_option( int& i, int argc, char* argv[] ) {
+  char* end_ptr;
+  double val = strtod( str, &end_ptr );
+    usage( "Expected real number following option", argv[i-1] );
+  return val;
+static void parse_ray( int& i, int argc, char* argv[] )
+  double params[6]; bool err = false;
+  for( int j = 0; j<6 && !err; ++j ){
+    if( ++i == argc ){
+      err = true; break;
+    char* end_ptr;
+    params[j] = strtod( argv[i], &end_ptr );
+    if( !argv[i][0] || *end_ptr ){
+  if( err ){
+      usage( "Expected ray specified as <x> <y> <z> <u> <v> <w>", 0, argv[0] );
-    int surf_id = dagmc.id_by_index( 2, dagmc.index_by_handle( surf ) );
-    std::cout << "dist=" << dist << " surf_id=" << surf_id << " new_xyz="
-              << x+dist*u << " " << y+dist*v << " " << z+dist*w << std::endl;
-    return 0;
+  MBCartVect point(params), direction(params+3);
+  direction.normalize();
+  ray_t ray; ray.p = point; ray.v = direction;
+  rays.push_back( ray );
-  } else {
-  bool full = false;
-  int i = 1;
-  if (!strcmp(argv[i], "-f")) {
-    full = true;
-    i++;
+int main( int argc, char* argv[] )
+  char* filename = NULL;
+  bool flags = true;
+  for (int i = 1; i < argc; ++i) {
+    if (flags && argv[i][0] =='-') {
+      if (!argv[i][1] || argv[i][2])
+        usage(0,argv[i],argv[0]);
+      switch (argv[i][1]) {
+        default:  usage( 0, argv[i], argv[0] );   break;
+        case '-': flags = false;         break;
+        case 'h': usage(0,0,argv[0]);    break;
+        case 's': do_stat_report = true; break;
+        case 'S': do_trv_stats   = true; break;
+        case 'i':
+          vol_index = get_int_option( i, argc, argv );
+          break;
+        case 't':
+	  facet_tol = get_double_option( i, argc, argv );
+	  break;
+        case 'n':
+	  num_random_rays = get_int_option( i, argc, argv );
+	  break;
+        case 'r':
+	  source_rad = get_double_option( i, argc, argv );
+	  break;
+        case 'f':
+	  parse_ray( i, argc, argv );
+          num_random_rays = 0;
+	  break;
+        case 'z':
+          randseed = get_int_option( i, argc, argv );
+          break;
+        case 'L':
+          location_az = get_double_option( i, argc, argv ) * (PI / 180.0);
+          break;
+        case 'D':
+          direction_az = get_double_option( i, argc, argv ) * (PI / 180.0);
+          break;
+    else {
+      if( !filename ){ filename =  argv[i]; }
+      else{ usage( "Unexpected parameter", 0, argv[0] ); }
-  double rad = atof(argv[i++]);
-  int vol_idx = atoi(argv[i++]);
-  ncalls = atoi(argv[i++]);
-  double location_az = 2.0 * PI, direction_az = location_az;
-  if (i < argc) location_az = atof(argv[i++]) * PI / 180.0;
-  if (i < argc) direction_az = atof(argv[i++]) * PI / 180.0;
+  if( !filename ){
+    usage("No filename specified", 0, argv[0] );
+  MBErrorCode rval;
+  MBEntityHandle surf = 0, vol = 0;
+  double x, y, z, u, v, w, dist;
+  /* Initialize DAGMC and find the appropriate volume */
+  std::cout << "Initializing DagMC, facet_tol = " << facet_tol << std::endl;
-  if (MB_SUCCESS != rval) {
+  if(MB_SUCCESS != rval) {
+    std::cerr << "Failed to load file '" << filename << "'" << std::endl;
     return 2;
     return 2;
+  vol = dagmc.entity_by_id(3, vol_index);
+  if(0 == vol) {
+    std::cerr << "Problem getting volume " << vol_index << std::endl;
+    return 2;
+  /* Fire any rays specified with -f flag */
+  if( rays.size() > 0 ){
+    std:: cout << "Firing user-specified rays at volume " << vol_index << std::endl;
+    for( unsigned i = 0; i < rays.size(); ++i ){
-  vol = dagmc.entity_by_index(3, vol_idx);
-  if (0 == vol) {
-    std::cerr << "Problem getting first volume." << std::endl;
-    return 2;
+      ray_t ray = rays[i];
+      std::cout << " Ray: point = " << ray.p << " dir = " << ray.v << std::endl;
+      rval = dagmc.ray_fire( vol, 0, 1,
+                             ray.v[0], ray.v[1], ray.v[2],
+                             ray.p[0], ray.p[1], ray.p[2],
+                             DBL_MAX, dist, surf );
+        std::cerr << "ERROR: ray_fire() failed!" << std::endl;
+        return 2;
+      if(0 == surf) {
+        std::cerr << "ERROR: Ray finds no surface.  Particle is lost." << std::endl;
+        // might as well keep going here, in case other user specified rays were given
+        continue;
+      int surf_id = dagmc.id_by_index( 2, dagmc.index_by_handle( surf ) );
+      std::cout << "       hits surf_id " << surf_id << " dist=" << dist << " new_xyz="
+                << ray.p+(ray.v*dist) << std::endl;
+  /* Fire and time random rays */
+  if( num_random_rays > 0 ){
+    std::cout << "Firing " << num_random_rays
+              << " random rays at volume " << vol_index << "..." << std::flush;
   double ttime1, utime1, stime1, tmem1, ttime2, utime2, stime2, tmem2;
   get_time_mem(ttime1, utime1, stime1, tmem1);
-    // initialize random number generator using ttime1
-  srand((unsigned int) ttime1);
+  srand( randseed );
 #ifdef DEBUG
   double uavg = 0.0, vavg = 0.0, wavg = 0.0;
 #endif
-  for (int j = 0; j < ncalls; j++) {
+  for (int j = 0; j < num_random_rays; j++) {
     RNDVEC(u, v, w, location_az);
-    x = -u*rad;
-    y = -v*rad;
-    z = -w*rad;
+    x = -u*source_rad;
+    y = -v*source_rad;
+    z = -w*source_rad;
-    if (rad >= 0.0) {
+    if (source_rad >= 0.0) {
       RNDVEC(u, v, w, direction_az);
@@ -199,50 +295,60 @@
   double timewith = ttime2 - ttime1;
     // now without ray fire call, to subtract out overhead
-    x = -u*rad;
-    y = -v*rad;
-    z = -w*rad;
-    if (rad >= 0.0) {
   get_time_mem(ttime1, utime1, stime1, tmem2);
   double timewithout = ttime1 - ttime2;
+  std::cout << " done." << std::endl;
+  std::cout << "Total time per ray fire: " << timewith/num_random_rays
+            << " sec" << std::endl;
+  std::cout << "Estimated time per call (excluding ray generation): "
+            << (timewith - timewithout) / num_random_rays << " sec" << std::endl;
+  std::cout << "Program memory used: "
+            << tmem2 << " bytes (" << tmem2/(1024*1024) << " MB)" << std::endl;
+  /* Gather OBB tree stats and make final reports */
   MBEntityHandle root;
   MBErrorCode result = dagmc.get_root(vol, root);
   if (MB_SUCCESS != result) {
     std::cerr << "Trouble getting tree stats." << std::endl;
     return 2;
-  unsigned int entities_in_tree, tree_height, node_count, num_leaves;
-  double root_volume, tot_node_volume, tot_to_root_volume;
-  dagmc.obb_tree()->stats(root, entities_in_tree, root_volume, tot_node_volume,
-                          tot_to_root_volume, tree_height, node_count, num_leaves);
-  std::cout << "Gross time per call, net time per call, memory = "
-            << timewith/ncalls << " " << (timewith - timewithout)/ncalls
-            << " " << tmem2 << std::endl;
-  std::cout << "Tree stats: facets, tree_height, num_leaves = "
-            << entities_in_tree << " " << tree_height << " " << num_leaves << std::endl;
-  if (full) {
-    std::cout << "Tree data: " << std::endl;
+  if (do_stat_report) {
+    std::cout << "Tree statistics: " << std::endl;
     dagmc.obb_tree()->stats(root, std::cout);
+  else{
+    unsigned int entities_in_tree, tree_height, node_count, num_leaves;
+    double root_volume, tot_node_volume, tot_to_root_volume;
+    dagmc.obb_tree()->stats(root, entities_in_tree, root_volume, tot_node_volume,
+                            tot_to_root_volume, tree_height, node_count, num_leaves);
+    std::cout << "Tree dimensions:" << std::endl;
+    std::cout << "   facets: " << entities_in_tree << ", height: " << tree_height << std::endl;
+    std::cout << "   num leaves: " << num_leaves << ", num nodes: " << node_count << std::endl;
 #ifdef DEBUG
   std::cout << "uavg, vavg, wavg = " << uavg << " " << vavg << " " << wavg << std::endl;
 #endif
   return 0;
