[MOAB-dev] Possible bug in MBParallelComm.cpp
    Roman Putanowicz
    putanowr at l5.pk.edu.pl
    Sat Jan 30 21:47:32 CST 2010
I looked at the code of MBParallelComm.cpp and noticed comment
that (as far as I understand the code) does not go with the code:
Starting at the line 2812 there is fragment:
// get entities adjacent to skin ents from shared_dim down to
// zero; don't create them if they don't exist already
  for (int this_dim = skin_dim-1; this_dim >= 0; this_dim--) {
       result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
                                        true, skin_ents[this_dim],
                                        MBInterface::UNION);
        RRA("Failed getting skin adjacencies.");
The third argument to get_adjacencies function has the value 'true'.
However the name of this argument is 'create_if_missing'
Is the code or comment wrong (or am I misunderstanding something) ?
Regards
Roman
Roman Putanowicz  < putanowr at l5.pk.edu.pl  >
Institute for Computational Civil Engng (L-5)
Dept. of Civil Engng, Cracow Univ. of Technology
www.l5.pk.edu.pl, tel. +48 12 628 2569, fax 2034
