[MOAB-dev] r3512 - in MOAB/trunk: . tools/iMesh
    jvporter at wisc.edu
    Fri Jan 29 16:09:01 CST 2010
Author: jvporter
Date: 2010-01-29 16:09:01 -0600 (Fri, 29 Jan 2010)
New Revision: 3512
Removed:
   MOAB/trunk/tools/iMesh/python/
Modified:
   MOAB/trunk/configure.ac
   MOAB/trunk/tools/iMesh/Makefile.am
Log:
Remove PyTAPS from MOAB (huge diff, ahoy!)
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2010-01-29 19:46:09 UTC (rev 3511)
+++ MOAB/trunk/configure.ac	2010-01-29 22:09:01 UTC (rev 3512)
@@ -215,134 +215,6 @@
 fi
-#                           Python
-AC_ARG_VAR([PYTHON],[Python interpretper])
-AC_CHECK_PROG([PYTHON],[python],[python])
-# Check if python interpreter works
-AC_MSG_CHECKING([if python works])
-py_command="from math import *; aTuple = ('robots', 77, 93, 'try'); \
-  sqrt(aTuple[[1]])"
-if ${PYTHON} -c "$py_command" >/dev/null 2>&1; then
-  AC_MSG_RESULT([yes])
-else
-  AC_MSG_RESULT([NO])
-  PYTHON=
-fi
-if test "x$PYTHON" != "x"; then
-    # Allow user to specify location of python includes
-  AC_ARG_WITH(python-includes,[AC_HELP_STRING([--with-python-includes=DIR],
-          [Specify directory containing Python headers])],
-          [PYTHON_DIR="$withval"],[PYTHON_DIR=])
-    # Get the default Python include dir containing pyconfig.h
-    # Note: Python does this automatically via distutils
-  AC_MSG_CHECKING([for location of python headers])
-  py_command="import sys; print '%s/include/python%d.%d' % (sys.prefix, \
-    sys.version_info[[0]],sys.version_info[[1]])"
-  if pydir_out=`$PYTHON -c "$py_command"`; then
-    PYCONFIG_DIR="$pydir_out"
-    AC_MSG_RESULT($PYCONFIG_DIR)
-  else
-    AC_MSG_ERROR("python interpreter is broken?")
-  fi
-    # If user did not specify an include dir, use the default
-  if test "x" = "x$PYTHON_DIR"; then
-    PYTHON_DIR=PYCONFIG_DIR
-  fi
-    # Determine location for python libraries
-  py_command="import sys; print '$libdir/python%d.%d/site-packages' % (\
-  pylibdir=`$PYTHON -c "$py_command"`
-  AC_SUBST(pylibdir)
-    # Check for expected header in python include dir
-  old_CPPFLAGS="$CPPFLAGS"
-  CPPFLAGS="$CPPFLAGS -I$PYTHON_DIR -I$PYCONFIG_DIR"
-  AC_CHECK_HEADER([pyconfig.h],[],[PYTHON_DIR=; AC_MSG_WARN([mis-detected python include dir])],[])
-  AC_CHECK_HEADER([Python.h],[],[PYTHON_DIR=; AC_MSG_WARN([mis-detected python include dir])],[])
-  CPPFLAGS="$old_CPPFLAGS"
-    # Check that NumPy module is installed
-  HAVE_NUMPY=no
-  AC_MSG_CHECKING([for NumPy module])
-  if "${PYTHON}" -c "import numpy.core" >/dev/null 2>&1; then
-    HAVE_NUMPY=yes
-  fi
-  AC_MSG_RESULT($HAVE_NUMPY)
-  if test yes = $HAVE_NUMPY; then
-      # Allow user to specify location of NumPy includes
-    AC_ARG_WITH(numpy,[AC_HELP_STRING([--with-numpy=DIR],
-            [Specify directory containing Numpy include directory])],
-            [NUMPY_DIR="$withval"],[NUMPY_DIR=])
-      # If numpy directory was not specified, guess
-    if test "x" = "x$NUMPY_DIR"; then
-      AC_MSG_CHECKING([for location of NumPy includes])
-      if test -d "${PYTHON_DIR}/numpy"; then
-        NUMPY_DIR="${PYTHON_DIR}"
-      else
-        py_command="import numpy.core; print numpy.core.__path__[[0]]"
-        NUMPY_DIR=`$PYTHON -c "$py_command"`/include
-      fi
-      AC_MSG_RESULT([$NUMPY_DIR])
-    fi
-    # Check for expected headers in NUMPY_DIR
-    CPPFLAGS="$CPPFLAGS -I$NUMPY_DIR -I$PYTHON_DIR -I$PYCONFIG_DIR"
-    AC_CHECK_HEADER([numpy/arrayobject.h],[],[NUMPY_DIR=; AC_MSG_WARN([mis-detected NumPy include dir])],[#include "Python.h"])
-  fi
-fi
-AC_SUBST(PYTHON)
-AC_SUBST(PYTHON_DIR)
-AC_SUBST(NUMPY_DIR)
-#                           PyTAPS
-AC_ARG_ENABLE([pytaps],[
-AC_HELP_STRING([--enable-pytaps],[Build Python iMesh interface.])
-AC_HELP_STRING([--disable-pytaps],[Don't build Python iMesh interface.])
-[ENABLE_pytaps="$enableval"],
-[ENABLE_pytaps=no]
-case "x$ENABLE_pytaps" in
-  xyes)
-#    if test "x$with_pic" != "xyes"; then
-#      AC_MSG_ERROR([Need PIC support for PyTAPS])
-#    fi
-    test "x"   != "x$PYTHON"       || AC_MSG_ERROR([Cannot build pytaps w/out python])
-    test "x"   != "x$PYTHON_DIR"   || AC_MSG_ERROR([Pytaps requires python C includes])
-    test "xyes" = "x$HAVE_NUMPY"   || AC_MSG_ERROR([Pytaps requires NumPy module])
-    test "x"   != "x$NUMPY_DIR"    || AC_MSG_ERROR([Pytaps requires NumPy C includes])
-    test "xyes" = "x$ENABLE_imesh" || AC_MSG_ERROR([PyTAPS requires iMesh])
-  xno)
-    AC_MSG_ERROR([Invalid argument to --enable-pytaps : $ENABLE_pytaps])
-esac
-AC_MSG_CHECKING([if Python support is to be built])
-AC_MSG_RESULT([$ENABLE_pytaps])
-AM_CONDITIONAL([ENABLE_pytaps],[test "xyes" = "x$ENABLE_pytaps"])
 #                              HDF5 OPTIONS
@@ -1101,7 +973,6 @@
                  tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
                  tools/iMesh/SIDL/Makefile
                  tools/iMesh/SIDL/common.make
-                 tools/iMesh/python/Makefile
                  tools/mbperf/Makefile
                  tools/mbchaco/Makefile
                  tools/mbcoupler/Makefile
Modified: MOAB/trunk/tools/iMesh/Makefile.am
--- MOAB/trunk/tools/iMesh/Makefile.am	2010-01-29 19:46:09 UTC (rev 3511)
+++ MOAB/trunk/tools/iMesh/Makefile.am	2010-01-29 22:09:01 UTC (rev 3512)
@@ -7,12 +7,6 @@
   babel_DIR =
 endif
-if ENABLE_pytaps
-  pytaps_DIR = python
-else
-  pytaps_DIR =
-endif
 SUBDIRS = . $(babel_DIR) $(pytaps_DIR)
 INCLUDES = -I$(top_srcdir) -I$(top_builddir) -I.
