[MOAB-dev] Possible bug in MBParallelComm.cpp
Tim Tautges
tautges at mcs.anl.gov
Sun Jan 31 08:55:59 CST 2010
The comment is wrong, we want the skin entities always, or at least at the present time. I'd call that a side effect of
resolving shared entities, so maybe that constraint could be relaxed eventually.
- tim
Roman Putanowicz wrote:
> Hi,
> I looked at the code of MBParallelComm.cpp and noticed comment
> that (as far as I understand the code) does not go with the code:
> Starting at the line 2812 there is fragment:
> // get entities adjacent to skin ents from shared_dim down to
> // zero; don't create them if they don't exist already
> for (int this_dim = skin_dim-1; this_dim >= 0; this_dim--) {
> result = mbImpl->get_adjacencies(skin_ents[skin_dim], this_dim,
> true, skin_ents[this_dim],
> MBInterface::UNION);
> RRA("Failed getting skin adjacencies.");
> The third argument to get_adjacencies function has the value 'true'.
> However the name of this argument is 'create_if_missing'
> Is the code or comment wrong (or am I misunderstanding something) ?
> Regards
> Roman
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
