[MOAB-dev] problems building mcnpmit
Paul Wilson
wilsonp at engr.wisc.edu
Fri Jan 29 16:25:30 CST 2010
Hi Bob,
mcnpmit is something we developed here and is deprecated. Its value as
an example is questionable since a big chunk of it has been replaced by
a reader that is in MOAB proper (ReadMCNP).
Unless anyone disagrees, we can probably delete this tool entirely.
Paul
Robert Smith wrote:
> I'm trying to build MOAB with as many of the tool options enabled as
> possible. I still have a couple to figure out but I'm getting compile
> errors in mcnpmit.
> Has anyone built this recently? I'm getting some build errors and I
> just wanted to make sure they are real errors and not some
> configuration issue on my part.
> If no one has built or used this recently then I'll correct the issues.
> --Bob
Paul Wilson
Paul P.H. Wilson 419 Engineering Research Building
wilsonp at engr.wisc.edu 1500 Engineering Dr
ph/fax: 608/263-0807 Madison, WI 53706
My calendar: http://bit.ly/pphw-calendar
Computational Nuclear Engineering Research Group
http://cnerg.engr.wisc.edu
Associate Professor, Nuclear Engineering
Engineering Physics Department
http://www.engr.wisc.edu/ep
Chair, Energy Analysis & Policy Certificate
Nelson Institute for Environmental Studies
http://nelson.wisc.edu/eap/
Contributing to the joy and improvement
of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100129/2b736d6d/attachment.bin>
