[MOAB-dev] problems building mcnpmit
    Tim Tautges
    tautges at mcs.anl.gov
    Fri Jan 29 21:22:14 CST 2010
Please make sure the element interpolation stuff has been reproduced in the code, I think it's in MBElemUtil, then do
please remove mcnpmit.
- tim
Paul Wilson wrote:
> Hi Bob,
> mcnpmit is something we developed here and is deprecated.  Its value as
> an example is questionable since a big chunk of it has been replaced by
> a reader that is in MOAB proper (ReadMCNP).
> Unless anyone disagrees, we can probably delete this tool entirely.
> Paul
> Robert Smith wrote:
>> I'm trying to build MOAB with as many of the tool options enabled as
>> possible.  I still have a couple to figure out but I'm getting compile
>> errors in mcnpmit.
>> Has anyone built this recently?   I'm getting some build errors and I
>> just wanted to make sure they are real errors and not some
>> configuration issue on my part.
>> If no one has built or used this recently then I'll correct the issues.
>> --Bob
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
