[MOAB-dev] MOAB Parallel Builds
Tim Tautges tautges at mcs.anl.gov
Wed Jan 6 20:20:20 CST 2010
Excellent, very welcome news.  Those are real failures (in contrast to the scdtest ones); this will motivate me to get
those fixed, or maybe Jason (Jason, let's talk tomorrow).
- tim
James Porter wrote:
> Starting tonight, the parallel test for MOAB on the Fath-o-Matic should actually be running in parallel (yay!). The problems with scdtest should be fixed (assuming I got the environment variables set up on the cron job properly), but there's now a handful of failures much later, in iMeshP_unit_tests.cpp. Below are the relevant bits of the log that I got from running the tests manually. The tests are running with MPICH2, HDF5 1.8.4, and with gfortran for the F77/F90 compilers (the MPICH2 build wasn't compiled with F90 support).
> - Jim
> Failed assertion: count == expected_global_vtx_count
>   at iMeshP_unit_tests.cpp:793
> Error code  1 at iMeshP_unit_tests.cpp:957
> test_get_by_type : FAILED!!
> Error code  1 at iMeshP_unit_tests.cpp:975
> test_get_by_topo : FAILED!!
> test_part_id_handle : success
> test_part_rank : success
> test_get_neighbors : success
> test_get_part_boundary : success
> test_part_boundary_iter : success
> test_get_adjacencies : success
> test_entity_iterator : success
> test_entity_owner : success
> test_entity_status : success
> test_entity_copy_parts : success
> test_entity_copies : success
> Rank 0 : getIntData failed for vertex 1
> Rank 0 : getIntData failed for vertex 2
> Rank 0 : getIntData failed for vertex 3
> Rank 0 : getIntData failed for vertex 6
> Rank 0 : getIntData failed for vertex 7
> Rank 0 : getIntData failed for vertex 8
> Rank 0 : getIntData failed for vertex 9
> Rank 0 : getIntData failed for vertex 10
> Rank 0 : getIntData failed for vertex 11
> Failed assertion: 0 == errcount
>   at iMeshP_unit_tests.cpp:2603
> test_push_tag_data_iface : FAILED!!
> test_push_tag_data_ghost : FAILED!!
> test_create_ghost_ents : success
> 4 TESTS FAILED!
> FAIL: iMeshP_unit_tests
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
