[MOAB-dev] buildbot failure in Fathom on moab-par
James Porter
jvporter at wisc.edu
Fri Dec 11 17:45:33 CST 2009
Starting tonight, Buildbot emails should be reporting the last 20 lines
of output from the last logfile generated by the build. It's still a
little bit brittle, and it's not going to be especially useful until I
trim out the plethora of "make[1]: Leaving directory `foo'" lines, but
it's a start.
I've also messed around with the CSS rules for the buildbot's web page,
which (in my opinion) greatly enhances its readability. I'll be tweaking
it more as time goes by, but again, it's a start.
- Jim
On Tue, 2009-12-08 at 16:56 -0600, Tim Tautges wrote:
> Excellent, this is what I wanted to see. I think it would be helpful to see at least some of the output from the
> failing build; is there a way to get a tail of the output? I've found it annoying when I have to browse the web just to
> find simple failures, so I think this is relevant even after the web links work.
> - tim
> James Porter wrote:
> > For those of you who are interested in that sort of thing, this is the default message that gets sent when the new buildbot encounters a failure. For those of you who don't have access to ANL's network, sorry, but the links won't work (we're working on that).
> > If you have suggestions for what the emails should contain (keep in mind that the links will be usable in the near future), let me know.
> > - Jim
> > ----- Original Message -----
> > From: buildbot at mcs.anl.gov
> > Date: Tuesday, December 8, 2009 12:05 am
> > Subject: [MOAB-dev] buildbot failure in Fathom on moab-par
> > To: moab-dev at mcs.anl.gov
> >> The Buildbot has detected a failed build of moab-par on Fathom.
> >> Full details are available at:
> >> http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/17
> >> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> >> Buildslave for this Build: bot1name
> >> Build Reason: The Nightly scheduler named 'nightly' triggered this build
> >> Build Source Stamp: HEAD
> >> Blamelist:
> >> BUILD FAILED: failed test
> >> sincerely,
> >> -The Buildbot
