[MOAB-dev] buildbot failure in Fathom on moab-par
James Porter jvporter at wisc.edu
Thu Dec 10 16:52:38 CST 2009
Buildbot emails should be working again. I changed the config and broke
them, so there hasn't been anything for the last two days.
In other news, the (still-in-testing and hopefully ultimately temporary)
daemon that polls the SVN server periodically to see if it should run a
post-commit build has been a little wonky, and didn't notice Brandon's
commit until I restarted it. I added some logging to it so hopefully I
can find the problem and get the post-commit builds running stably
enough that I can turn email on for them too.
- Jim
----- Original Message -----
Date: Tuesday, December 8, 2009 12:05 am
Subject: [MOAB-dev] buildbot failure in Fathom on moab-par
To: moab-dev at mcs.anl.gov
> The Buildbot has detected a failed build of moab-par on Fathom.
> Full details are available at:
>  http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/17
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: bot1name
> Build Reason: The Nightly scheduler named 'nightly' triggered this build
> Build Source Stamp: HEAD
> Blamelist:
> BUILD FAILED: failed test
> sincerely,
>  -The Buildbot
